Poll: Happy with your 4.7? - Page 9 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
View Poll Results: Are you happy with your 4.7L V8?
Love my 4.7 204 41.98%
Kind of wish I went with the 5.7 137 28.19%
REALLY wish I went with the 5.7 107 22.02%
I'm not picky.. 38 7.82%
Voters: 486. You may not vote on this poll
Old 10-03-2011, 02:12 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yeah that's basically a 33.5-34" diameter tire, not toooo huge, although also very wide, definitely some mpg loss there. You'd gain some back probably with 3.92's or 4.10's...but that's another topic...
I'd try the dealership and tell them what happened and maybe they'll have an answer for you...Seems like the problem started with them...
Sean
Old 10-03-2011, 02:17 PM
DirtyD's Avatar
DirtyD DirtyD is offline
Vehicle: 03 2500
Color: Gray
Rep:45
DirtyD is on a distinguished road
idk about those guys.. they try to tell me that with my tires my speedo wouldnt be that far off and that it doesnt matter how fast u go, it will stay the same off.. when i know the faster you go the more off it is.
03 2500 ( Hemi ), 8" lift and 38" Toyo Open Country M/T
Old 10-03-2011, 02:28 PM
snrusnak's Avatar
Rep:1388
what size were your stock tires? and yeah you're right it's off by a percentage, so faster makes it thrown off more.
Sean
Old 10-03-2011, 02:47 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
stock tire size is 245/70R17
Old 10-03-2011, 03:00 PM
snrusnak's Avatar
Rep:1388
If my math's correct:
33.5"/30.5" = ~109.8% so at 70 mph 70(1.098)=6.86mph difference
That's not that much....I'd see if the dealer can set it back to what it was so you can see if you mpg improves... keep in mind your odometer would be off though...
Sean
Old 10-03-2011, 03:06 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
my wife got pulled over doing 58 the cop said she was doing 70
Old 10-03-2011, 03:12 PM
snrusnak's Avatar
Rep:1388
should be like 64mph if the speedo said 58mph...
Sean
Old 10-03-2011, 08:07 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
This site gives a great comparison. Just plug in the two tires sizes.
http://www.1010tires.com/TireSizeCalculator.asp
You were very close snrusnak. His speedo is actually off by 10.84% and reading too slow, of course. Your calculation was off by just a hair because his current tire is actually 33.81 inches tall. That still doesn't make up for the alleged 70 mph reading as 58 mph though. Is she certain when he clocked her? Maybe a bad clock? Who knows? If she didn't get a ticket I wouldnt worry about that too much because there are a lot of variables with radar that could have caused that. With that percentage (and before the dealership "fixed" it) if your speedo said 55 mph you would actually be going about 61 mph. Speedo 60 mph would actually be about 66.5 mph. And speedo 70 mph actually about 77.6 mph.
As for your gas mileage.....I don't know if the digital reading uses a distance reading (such as from your speed sensor) to calculate the gas mileage or not but if it does then it makes sense for the bigger tires to alter the calculated mileage as well. Not including the dealer "fix" your truck is actually traveling 1.10 miles for every mile that it thinks it traveled. So you would be getting an extra tenth of a mile for every one of those gallons that your truck is reporting as miles per gallon. What's odd is that if your were getting 10-11 before the dealer fix and now you are getting 8-9.....that's an almost exact 10% reported loss. The weird part is that you should have observed that reported loss when you put on the bigger tires, not when the dealer "fixed" it, lol.
Here's a theory...once again, not knowing how the dealer "fixes" the reading (but assuming they alter the tire diameter through new input to the PCM just like a programmer) is it possible they went in wrong direction and effectively made your speedo off by nearly twice as much? That would come closer to explaining the radar clock (70 mph x 0.2168 (which is your tire size difference doubled) = 15.1 mph off which would read about 55 on your speedo. It would also explain why your reported mileage dropped after the "fix". Once again, this is all assuming the truck uses the measured speed to calculate the mileage. If not, disregard the last two paragraphs, lol.
Simple solution...calculate it by hand. Your calculation will always vary from the display but if you get a hand reading that is higher than your display reading then you can pretty much guarantee the display is wrong for some reason. Good luck!!
Old 10-03-2011, 08:13 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
Ya she said she was sure, and she did get a ticket, that is when i went and had them "fix" it. i also bought the truck with those tires on it. the dealership said they set the tire size in the PCM to as close as they could to what was on my truck. when i get the money i am getting a programer so i can go in and set the tires, and other stuff.
Old 10-03-2011, 08:45 PM
Rep:367
Ahhhhh, so she got clocked before they "fixed" it. In that case, just like snrusnak said...a speedo reading of 58 mph should be about 64.2 mph. Can't explain that other than maybe the radar was off or more likely the officer was mistaken or made an improper clock. Sadly, not much you can do about that usually. Not sure about your area but here in NC your best bet would be to explain the larger tires throwing off the speedo and ask for a reduction.
That does still make sense about the dealer throwing your speedo further off though. Take your readings before the dealer fix and add the 10.84% back and your truck would be getting 11-13.3 mpg with stock tires. That is still pretty crappy but closer to what you would expect. My 2006 4.7 quad cab auto 4x4 with the 3.92 gears averages about 13-14 and maybe 15.5 on the highway if I keep it in the sweet spot around 70.
Happy Belated Birthday to our Nick!!!! iRESQu Off Topic Discussion 13 10-07-2010 08:57 AM
Another happy owner Luger Newbie Checkin! 17 09-24-2009 09:02 AM
Happy Birthday, Stacy aka BlueJet DaveDees Off Topic Discussion 24 01-27-2009 01:34 AM
Happy Birthday 300Addict cowboytruckn Off Topic Discussion 9 08-05-2008 03:51 PM
