Need help with my gas mileage!!!! VERY BADLY - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Old 08-13-2011, 02:41 AM
MoparGuy86's Avatar
MoparGuy86 MoparGuy86 is offline
Vehicle: 1985 Dodge D250 5.9 2WD
Color: Faded Gray
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
MoparGuy86 is on a distinguished road
Originally Posted by Gen1dak View Post
At the very least I'd pull the intake and replace the plenum gasket. Normally when they fail, the truck runs worse and worse. In your case, with the aftermarket stuff may be minimizing some of the usual symptoms, but you can't hide from poor mileage. I have a '93 360 mag 3/4 ton with 4.11 rear and taller than stock rear tires that probably put the final drive into the mid-3's. Haulin' it down I-10 75-80mph and it knocks down a smidgen over 15mpg. Have you reset the computer?
I don't think I have reset the computer... how do I do that? and i have already replaced that gasket, forgot to mention that earlier.
Old 08-13-2011, 03:16 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Keep in mind after reset your system will need to run a couple hundred mikes to re-learn the basics, but a reset is sometimes a necessary deal. A computer is reset with the code reader tools, but a shade tree reset can be done by simply pulling the battery cable off for a few minutes (my method of choice). One may also pull both battery cables off, touch together, then re-attach to battery. Either way, the computer will reset to baseline.
Old 08-15-2011, 07:04 PM
DRAM1500's Avatar
DRAM1500 DRAM1500 is offline
Vehicle: 1998 Dodge Ram 1500 4x4 QCSB
Color: RED
Rep:25
DRAM1500 is on a distinguished road
Default MPG Gains
I saw your thread & I have a 98 Ram 1500 5.9 & I have done tons to it & get 20MPG+ per tank. Here is what you do.
E3 Sparkplugs
MSD Coil & Wires
Air Intake with K&N Filter
Synthetic 5w20 Oil & K&N Filter
Synthetic Tranny Fluid
Synthetic Differential Fluid Change(every 50K)
Remove Motor Fan - Install Electric Fans
Superchips Flashpaq Prog - Set on Mileage XS
Use Hypermiling Techniques - Coast when possible
TBI 1" Spacer
Headers & Dual Exhaust CherryBomb Glasspaqs
New GBH Bearings packed in Synthetic Grease
The two best things from the list is (1) Hypermiling Techniques & the SC Flashpaq Programmer set on Mileage XS
I ABSOLUTELY HATE paying for fuel, here in the Toronto area gas is about $4.40 USD per gallon which hurts like hell when filling up!
Old 08-15-2011, 07:29 PM
DRAM1500's Avatar
Color: RED
Rep:25
Default Mpg
I forgot to put in I put on a new tensioner pulley & belt, also tire PSI is at 55PSI.
Old 08-15-2011, 07:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
is DRAM1500 the same person who posted another thread about achieving like 24mpg or something in city and 30mpg + on hwy.....?
Sean
Old 08-18-2011, 11:38 PM
MoparGuy86's Avatar
Color: Faded Gray
Well I have an update My mileage has gone from 7.3 to 8.8, and the only thing that have changed is the gas I'm using. Since we moved recently I have quit using QT gas and started using BP, because it is right up the street. I have been reading that their gas is a whole lot better than QT. So that's a heads up for others to try. The other thing is we have gone from low 100 degree temps to mid to low 80's now. The next strep I'm going to take is changing the diff fluids and transfer case fluid. I want to do the trans but I don't want to mess up a working tranny with the way these dodges are lol. So... What fluids do you all suggest I use in the diff's and trans case????
Old 08-19-2011, 01:28 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Well I can only speak for the older transmissions and what I have to say is that they are great transmissions believe it or not, the reason why people have begun to say they suck and a reputation has built up is because of things you are not doing. It's when you don't maintain the transmission does it start acting up also the biggest thing is when you take it to a mechanic and they decide to use Dex or Merc instead of ATF+3/4. So my recommendation to you is to bring it to a good transmission shop and have them flush it and adjust the bands and replace the filter. Make sure they use a rubber gasket instead of cork and never use RTV as it isn't impregnable to ATF. As for fluid recommendations I have always made well with Valvoline I use Valvoline as my transmission fluid, engine oil, gear oil, brake fluid, power steer fluid, fuel inject cleaner, and more... As for filters I just use the standard chrysler oem oil filter as I tried fram and it had a leak and tried wix and all them and they did fine but I figure let me just use the oem it's only a couple dollars more then a fram. As for the transmission filter I buy the transmission filter kit from advanced auto made by Pro King, come with two gaskets for the two different pans. Then for the air filter I just use a fram. But as far as fluids I trust Valvoline my family has and I get excellent results. This is just from my use and my opinion. The only fluid that I use that isn't valvoline right now is the anti freeze because my local autoparts stores don't sell valvoline's antifreeze so I would have to order it online and I figure I change the fluid out every year or so and use distilled water so it should be fine. I do recommend if you need to clean your radiator you can just use that peak flush and cleaner stuff I need two bottles cause of the size of my system but you as well could, I run it with distilled water for a little over a week on off driving, I do that because I'm prone to clogs and had one on the highway and you can guess I did overheat a little but I slowed down and drafted behind a tractor trailer with the heat on high and was able to make it home all 50 miles on E lol... So anyways valvoline does great for me.
Old 08-28-2011, 06:58 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
That's real interesting about the QT gas. That's who I always use too. I've got damn near all the same mods as you minus the Superchips (which I did have but sold). I'm getting 8.5 mpg. I don't drive very far to work so it's not as much a deal breaker for me as you, but I've just be resigned to not being able to get any better with this truck. I had an '01 a few years back and got 10 mpg. I'm of the mind that it's just that damn fuel thirsty 5.9.
Rain-X Latitude wipers; Volant CAI - with ram air tubing; custom y pipe; Xlerator racing muffler; cats delete HemiFever custom Diablo tune; Line-X; Putco SilverLux LED headlamps; Putco Luminix LED fog lamps; Bilsteins 5100's all around, leveled up front; BFG AT KO 2's; KMC XD Battalion rims
Old 08-28-2011, 07:02 PM
TerrysRam's Avatar
Rep:16
E3 Sparkplugs
MSD Coil & Wires
TBI 1" Spacer
Are you for real? 20mpg? Are you all highway? I'm assuming the electric fan had to make a big difference. Hypermiling? I'm guessing that is the major difference. That's a lot of work when you're driving in order to save some money, but I guess everyone has their own priorities.
Old 08-29-2011, 02:19 AM
MoparGuy86's Avatar
Color: Faded Gray
Well as of today, my wife drove it this weekend about 400 miles round trip. When she got back she told me the truck was getting 11.1, I didn't believe her so I went and looked and sure as shit, it is! The next step I plan on doing is changing all the fluids and switching them to synthetic, But I'm not sure what to run. I have been thinking of using Royal Purple, but i don't know if I want to spend the money on it yet or not. I haven't herd enough good or bad to decided, well besides the guys on tv who get paid to use it, of course they are not going to talk bad about it.
Tune Up = Worse Gas Mileage? gain11 5.7L (345 cu in) HEMI V8 Specific Topics 19 01-13-2012 01:13 PM
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
Interesting Gas Mileage Change Big Daddy Diablo Predator Questions & Info! 5 06-24-2011 09:13 PM
Stock Mileage and how to increase it? yzracer Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 13 04-03-2011 12:26 PM
Ok maybe I'm crazy - funny EVIC happening today with mileage hpc3 2010 Dodge Ram Forum 8 06-17-2010 09:39 PM
