Old 08-09-2011, 11:32 PM
Lie2me Lie2me is offline
Vehicle: 2011 CC 2wd
Rep:26
Lie2me is on a distinguished road
Old 08-09-2011, 11:54 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Hahahahahha......
I was meaning 'photographic' evidence. Like, what it looks like with the seat folded forward.
brad
Interested in one of my mods?
Old 08-10-2011, 08:10 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^LOL
that does help but yeah we would still like pics/ maybe a video proving it securely latches
You may have convinced me not to use spacers...
Sean
Old 08-10-2011, 08:12 AM
Frank Drebin Frank Drebin is offline
Vehicle: 2011 RAM CC SPORT
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:34
Frank Drebin is on a distinguished road
Will do Gents...will do. I even took a vid last night.
Gimme a little bit.
Three Generation Dodge Ram Owner - 1998, 2003, 2011
Old 08-10-2011, 08:39 AM
Rep:34
1. Remove the seat. Each side is held down by 4 - 18mm head bolts. I used a breaker bar then a Ratchet.
2. When you fold the seat down, you'll see the clips. I don't have a clear pic of one before cutting. I would recommend using a hacksaw and taping the plastic guide to the metal so it doesn't break like it did on me. If you look closely at the plastic guide, you'll see two ridges. I cut the metal right in line with the second (lower) ridge. This was the perfect length. Cut longer the first time if you're not sure.
3. Reinstall the seat with the back folded down, test it out.
Heres a pic of the seat folded down, in the locked position. You can see how much of the latch is still engaged. That's why I say no worries about safety.
Cheers
Old 08-10-2011, 09:53 AM
brad12kx's Avatar
Rep:2581
Now we're talk'in.
Great mod! A great mod with 'How To', and backed by pix and video evidence.
brad
Old 08-12-2011, 10:07 AM
KRAZYK's Avatar
KRAZYK KRAZYK is offline
Vehicle: 2010 Dodge Ram 1500 CrewCab
Rep:92
KRAZYK will become famous soon enough
I have a foxbox.. and the spacers installed.. I will see if I can fold the seat down as soon as I get off work.
I had no idea it was even remotely possible.
SuperChips FlashPaq | 6000K HIDs Hi/Low | custom DIY intake | CherryBomb Glasspack | Daystar 2.5" Leveling Kit + Bilstein Shocks | 5% tint front and back | smoked tail lights and 3rd light | Pioneer AVH-P3200 2DIN + SIRIUS tuner | Reverse Camera | Kicker ZX700.5 | Kicker S10L5 sub in a FoxBox
Old 08-13-2011, 12:16 AM
KRAZYK's Avatar
Rep:92
Ok so like I said earlier I have the foxbox spacers installed.. and my seat DOES fold down now!
as you lift the seat up about 3/4ths of the way - when the back of the seat is at its highest point, you can pull it right down. No cutting needed.
Not a ton of room back there but I might mount my amp back there now
Old 08-13-2011, 10:15 AM
Rep:34
There is definitely room back there to mount an amp. I think you may run into issues if you run with the seat folded up all the time, because the seat folds into that space. I still think there is a good 3" with the seat folded up, once you remove the bulky insulation.
I'm taking the insulation off, and am going to try design an amp rack that encloses the two vents, while still leaving them functional.
Gonna treat the back wall with Dynamat and 1/2" dynaliner.
What's the size of your seat spacers? Mind taking a measure for those who dont want to cut?
Old 08-13-2011, 12:52 PM
KRAZYK's Avatar
Rep:92
my spacers are made out of wood, about 3/4 inch thick, 2 inch wide and about 12 inches long. just gotta drill the holes for the bolts to pass through and your all set.
Driver's side seat foam problems? I have the cure! TheAverageJoe Body & Interior 41 03-16-2015 08:58 PM
Next mod, Dodge Leather Sideless seat covers... ArmyofOne Dodge Ram General Discussion 4 05-16-2011 08:41 AM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 09:33 PM
back seat firecat Body & Interior 4 12-11-2010 10:03 PM
