Old 08-13-2011, 02:19 PM
Frank Drebin Frank Drebin is offline
Vehicle: 2011 RAM CC SPORT
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:34
Frank Drebin is on a distinguished road
Originally Posted by KRAZYK View Post
my spacers are made out of wood, about 3/4 inch thick, 2 inch wide and about 12 inches long. just gotta drill the holes for the bolts to pass through and your all set.
I see. So there are 4 spacers, that basically go from front to back on each seat bracket?
Do you notice any difference in appearance/comfort with the seats raised 3/4"? I'd imagine not.
FWIW I have crawled under the truck to see how much extra the seat/seatbelt hold down bolts have after the threads - to see if you would need to get longer bolts if you did use a spacer.
There is about 3/4"-1" of exposed threads visible under the chassis, so I don't *think* there should be a need to get longer bolts. Something I'd check on just to be sure. It would be dangerous if the bolts were too short and not threaded in fully.
Three Generation Dodge Ram Owner - 1998, 2003, 2011
Old 08-13-2011, 02:42 PM
KRAZYK's Avatar
KRAZYK KRAZYK is offline
Vehicle: 2010 Dodge Ram 1500 CrewCab
Rep:92
KRAZYK will become famous soon enough
my seats only needed 2 spacers.. if you have the split seat it might be different then mine. I have the single bench seat in the back of my 2010 CC.
SuperChips FlashPaq | 6000K HIDs Hi/Low | custom DIY intake | CherryBomb Glasspack | Daystar 2.5" Leveling Kit + Bilstein Shocks | 5% tint front and back | smoked tail lights and 3rd light | Pioneer AVH-P3200 2DIN + SIRIUS tuner | Reverse Camera | Kicker ZX700.5 | Kicker S10L5 sub in a FoxBox
Old 09-10-2011, 01:06 PM
rlandon's Avatar
rlandon rlandon is offline
Vehicle: 2010 Dodge Ram Crew Cab 2WD
rlandon is on a distinguished road
Not a ton of room back there but I might mount my amp back there now
Did you mount your amp there? I have the same amp and just did the mod. Now to figure out where to mount the 700.5 amp and MS-8. I don't think both will fit thanks to the vents. I'll have to build a board to mount them I guess?? Let me know how you do yours and vice versa.
Previous Rams: 1954 C1-B6 Rodded, 1976 D100, 1994 RC, 1998 Supercharged EC, 2003 QC R/T Custom.
Old 09-10-2011, 05:36 PM
Rep:34
I pulled the insulation off and created a roughi template for the rack to fit within the vents etc.
I had enough room for
Massive hd 1600.4
Massive nx2
ms8
Jl audio 500/1
2 ck6 crossovers
Distribution blocks
Old 09-10-2011, 10:42 PM
rlandon's Avatar
Frank, I left out the oem insulation from the back wall also. How did you attach your board? Could I ask to get a pic or two of how you have yours mounted.
My plan is to use the top section of the insulation to cover the rear power window motor and cables then cut the bottom off and use it for the template to make a board and mounts. The top mounts will screw into the sheetmetal where gapped just underneath the window and the bottom mount to the seat bolts in an L shaped bracket. I can run the wiring behind the board using the gap and still hide the vents. Sound possible?
Gotta ask how that slant six powers the 2011 Ram?
Old 09-25-2011, 11:46 PM
ehenson99's Avatar
ehenson99 ehenson99 is offline
Vehicle: 2011 Dodge Ram Sport 4x4
Color: Deep Cherry Red
ehenson99 is on a distinguished road
I installed 3/4" MDF spacers that I fabbed up today and YES the bolts are plenty long enough. I haven't checked if the seats will fold down yet.
Old 09-26-2011, 12:30 AM
mnslawn's Avatar
mnslawn mnslawn is offline
Vehicle: 2009 Dodge Ram
mnslawn is on a distinguished road
Any pics of the board and amps mounted up ???
Old 09-26-2011, 12:23 PM
Rep:34
Working on it
http://www.ramforumz.com/showthread.php?t=91976
Old 09-26-2011, 01:02 PM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
I wish Dodge would redesign the back seats on these trucks. I think Fords completely flat carpet floor is just way better. Also, there is no technical reason why our pasenger seat can't fold flat into a hard work space table (like Titans). And while dreaming about better design wouldn't it be amazing if back seats could also be pulled out toward the front to make a cushioned bed. To me back seats should be as low and reclined as possible. The space is there.. it's all about design!
Take for example the RamBox.. its gonna be the envy of the rest. I'm sure Rambox alone might motivate trade ins and turn more than a few Chevy and Ford guys into Ram owners.
Why not have it all?
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 09-26-2011, 01:12 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Wow sounds like you're dreaming of designs lol. Would be cool though...
As far as the ramboxes, they are somewhat unique, but the concept has been around forever (old fords had bed side storage compartments....titans also do I think...
Sean
Driver's side seat foam problems? I have the cure! TheAverageJoe Body & Interior 50 11-06-2015 07:21 PM
Next mod, Dodge Leather Sideless seat covers... ArmyofOne Dodge Ram General Discussion 4 05-16-2011 09:41 AM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 03:16 AM
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 10:33 PM
back seat firecat Body & Interior 4 12-11-2010 11:03 PM
