Old 01-30-2012, 03:22 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
Thanks for sharing your video, looks like you got it working, I may try it again one day... Took a little time to align the spacers as I had to use 2 to get the exact 5/8 in height... Thanks
So it is written ! So it shall be done!
Old 01-31-2012, 02:26 AM
2k84by's Avatar
2k84by 2k84by is offline
Vehicle: 2014 Dodge Ram 1500 SLT
Color: silver
Rep:19
2k84by is on a distinguished road
Did this yesterday. I went with the cutting option instead of the spacer. Took all of 5 minutes with a grinder and cut off wheel, plus another 5 minutes of "clean up". Love the ability to fold the seat down, not sure how much i'll really use the option, but it's very nice when working on the amp i have mounted on the back wall. Great free mod.
To those of you using multiple spacers/washers to lift your seat. Please don't do this, it makes the bolt that holds your seat down much easier to bend, and much easier to break. If you are going to do this, do it the right way....not with a block of wood....use a square piece of metal that is as wide as the base of the seat and as tall as you're looking to raise the seat. Hollow or solid metal works, if using hollow metal use two bolts per mounting point. 1 from seat to metal, 1 from metal to frame. Also make sure to use pieces with a thicker wall. These pieces at a local metal shop will cost you about $10, this includes the bolts.
I understand about cutting corners to save money when doing modifications, but when it comes to safety, that's not the place to cut.
Old 06-01-2013, 02:10 PM
miamidad miamidad is offline
Vehicle: 2012 Ram Express Crew Cab
Trim Level: LSD, TBCG
Rep:54
miamidad will become famous soon enough
thanks for all the info. I just did it to my 2012 Ram Express Crew Cab.
here is where i posted the pics and my progress.
http://www.ramforumz.com/showthread....3812#undefined
thanks.
Old 11-10-2013, 10:17 PM
Bluedragon436's Avatar
Bluedragon436 Bluedragon436 is offline
Vehicle: 2009 Ram 1500
Bluedragon436 is on a distinguished road
Might have to look into doing this to my 09, as I've been thinking of mounting my amp on the back wall, and would like access to it in case it's needed..
Old 12-04-2013, 03:35 PM
Lonewolfjustin Lonewolfjustin is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT (Custom)
Color: Blue
Lonewolfjustin is on a distinguished road
My question is, whether its cutting the bracket or using spacers, why is this something Ram didn't do for us. If the option is there and it makes sense to have access to the back wall, why is this a Mod and not something done at the factory. It just seems so easy that it's silly we have to do it.
Old 11-18-2014, 11:41 AM
VTBighorn's Avatar
VTBighorn VTBighorn is offline
Vehicle: '14 RAM 1500
Trim Level: Bighorn
Color: TRUE BLUE
VTBighorn is on a distinguished road
Just finished mine, didn't gain a ton of room but it's nice to be able to get back there if need be. No spacers just chopped the bottom legs off of the hooks. It still locks secure and doesn't move.
'14 Bighorn QC
Driver's side seat foam problems? I have the cure! TheAverageJoe Body & Interior 41 03-16-2015 08:58 PM
Next mod, Dodge Leather Sideless seat covers... ArmyofOne Dodge Ram General Discussion 4 05-16-2011 08:41 AM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 09:33 PM
back seat firecat Body & Interior 4 12-11-2010 10:03 PM
