Old 08-09-2011, 04:23 PM
MADDOG MADDOG is offline
Rep:22
Default Determining Speedometer Error Due To Tire Size Change
When you change tire sizes, you will experience some speedometer error. Indicated speed may not be your actual speed.
So, if you are curious about how big of a change you will experience, go here:
Speedometer Error Calculator
Then, plug in your stock tire size (or your current tire size if you have adjusted your PCM for this using a programmer) and the new tire size to see what the change will be.
Old 08-09-2011, 05:00 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
http://www.1010tires.com/tiresizecalculator.asp
That is the tool I like to use as well. It has other handy calculations along with your percent difference of tire sizes
Old 09-14-2011, 07:04 PM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default Already swapped tires?
For those of you who have already swapped tire sizes before using one these handy calculation tools, get a gps unit, most will tell you exactly what your true speed is.
Old 09-25-2011, 10:12 AM
pall2509 pall2509 is offline
Vehicle: 2001 Dodge Ram
pall2509 is on a distinguished road
good stuff, i also use my garmin!
Old 10-13-2011, 09:56 AM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
is there no way to calibrate the tire change in the computer?
what are the ramifications of going from 20 to 17?
Old 10-13-2011, 10:43 AM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
A programmer (Predator/Trinity) can be used to change the tire size in the PCM.
As far as going from 20" to 17"- lots of factors to consider, but the main ones are overall tire diameter, rim/tire weight, and rim offset (aftermarket rims). You can go from a stock 20 to a 17, keeping the overall diameter the same, and you'll have no problems.
Old 05-02-2012, 01:42 PM
DrumMedic's Avatar
DrumMedic DrumMedic is offline
Vehicle: 2012 Ram 2500 CCSB 4x4
DrumMedic is on a distinguished road
Would a dealership or garage do this re-calibration for you?
2012 / 2500 / CCSB / ST / 4x4 / 6.7L CTD / G56 / 3.42 / Stock for now ...
Old 08-29-2012, 10:27 AM
JHemi1's Avatar
JHemi1 JHemi1 is offline
Vehicle: '11 SLT Crew w/Rambox Coolers
Rep:30
JHemi1 is on a distinguished road
Curious about this as well
Old 08-29-2012, 10:31 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Dealership can for a price but you 11-12 folks can purchase the Hypertech which can be used to calibrate your speedometer per tire metrics.
Old 08-29-2012, 02:29 PM
JHemi1's Avatar
Rep:30
Interesting to know. I didn't think there was anything you could do with a programmer. But then again, if the dealer can do it, there's got to be a way. Now to find someone local lol
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 91 05-06-2015 04:41 PM
Tire relation to Speedometer Zac2109 Dodge Ram General Discussion 9 06-27-2011 05:43 PM
Moto Metal Tire and Wheel Size? quadboy47 Dodge Ram Wheels And Tires 2 05-30-2011 01:18 PM
Changing tire size 67Polara Diablo Predator Questions & Info! 2 05-29-2011 09:04 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
