Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
ZDOG
Old 08-09-2011, 04:52 PM
tbmarinetech24 tbmarinetech24 is offline
Vehicle: 2006 Dodge Ram 1500 Quad Cab
Trim Level: sxt
Color: metallic silver
tbmarinetech24 is on a distinguished road
Default 2006 v-6 1500 getting p0499 code.
What does the code list for options?
Old 08-12-2011, 04:00 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Just what code is this? I don't have an answer so, it's time to .................... this back to the top!
Old 08-12-2011, 04:17 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
P0499 Evaporative Emission System Vent Control Circuit High
I don't know alot about the EVAP system but it is completely emissions related (as in no poor running conditions) as far as I know...
Sean
Old 10-02-2013, 12:24 PM
ron66 ron66 is offline
Vehicle: 2006 dodge ram
Color: red
ron66 is on a distinguished road
I have a 06 ram 1500 v6 wont start wont turn over. I can cross the post on the starter and it turn over, help
Old 10-14-2013, 10:25 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Hey Ron,
Post your question in here in the 3rd gen specific V6 engine subforum. More specifically, start you own thread here. You'll get a lot more response than just posting the question in an already started thread. We call that hijacking the thread.
The way you worded the question, it sounds to me like you have 2 different issues. 1) the starter won't engage and B) when you cross the wires, it will not fire. So lets address the first issue. Try swapping relays and see what happens. 2nd issue - you need 3 things for an internal combustion engine to work, fuel (gas and air), spark and compression. Take out any one of those things, and you won't get 'er fired up.
Have you been hit in the rear bumper lately? Sometimes just a small tap will engage the fuel cutoff switch. Check all of those things and then post the results. With more information, we can get a little farther with the diagnosis.
Old 10-14-2013, 12:26 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
Here is what I found, hope it helps:
Symptoms Symptoms of a P0499 DTC will include Malfunction Indicator Lamp (MIL) illumination, you will likely not notice any other symptoms. Causes Potential causes may include: Faulty vent valve Wire/circuit issue PCM/EMC/ECM fault Possible Solutions Some steps to take to diagnose and repair this trouble code include the following: Check your fuses, there may be a fuse that powers the vent solenoid. Check for a rubbed-through or chafed wiring harness. Check both wires to see if they are shorted to each other, to ground or power. Visually inspect the vent valve for cracks or damage. Trace the wires to and from the PCM/EMC/ECM and check for continuity continuity using a digital volt ohm meter (DVOM). If you have access to an advanced level scan tool, actuate the valve while reading power and ground at the connector or by simply using a bulb wired to both terminals, it will light up if power and ground are OK. Using a DVOM, check the resistance of the vent, in most cases the resistance reading should be low, refer to the manufacturer’s specification or compare it to a new one. Too high or low a value indicates a faulty coil inside the valve, thusly meaning replacement is necessary. This code seems to be prevalent on Dodge, Chrsyler, and Jeep products. In those cases the vent valve was bad. With GM products (specifically pickups), GM has released a new updated valve assembly. Finally, remove the valve, you may be able to access the pintle inside and it simply could just be sticking from fuel residue. Clean it and retest.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
2003 1500 ram 4.7 po306 code need help mfever 4.7L PowerTech V8 Specific Topics 5 04-11-2011 10:25 PM
2006 ram 1500 wheel size rammit916 Dodge Ram Wheels And Tires 2 01-09-2011 02:24 AM
2006 1500 misfiring on #2 steve154 4.7L PowerTech V8 Specific Topics 4 05-02-2010 11:29 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
HIDs for friends 2006 Ram 1500 JuansRam1500 Custom Dodge Ram Interior and Exterior Lighting 5 12-08-2009 11:01 PM
