Old 07-24-2011, 09:54 AM
USMCLcpl0311's Avatar
USMCLcpl0311 USMCLcpl0311 is offline
Vehicle: 1992 Dodge Ram D250
Trim Level: Dunno?
Color: Grey
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
USMCLcpl0311 is on a distinguished road
Default 1992 12 Valve A/C Questions!
Hey guys. I just bought a 1992 Cummins D250 Extended Cab with 152000 miles. Awesome looking truck for the year. The A/C is barely blowing and when it does it doesn't blow cold. So I was wondering what needs to be done to fix it? About how much?
2001 Toyota Solara- Wife's car. 1992 Dodge D250 Cummins Diesel-THE GREY FOX! I FINALLY HAVE ONE!
Old 07-27-2011, 07:45 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 08-03-2011, 07:09 PM
Sledneck's Avatar
Sledneck Sledneck is offline
Vehicle: 1998 Dodge Ram Club Cab 2 Door
Color: Midnight Blue
Sledneck is on a distinguished road
It could be something as minor as needing to recharge your A/C, as for the blowing there could be a an old and worn fan motor, or maybe a bad connection. If you do decide to try to recharge your A/C system, check for leaks with shaving cream or soapy water on the piping. The leak may be causing the A/C to lose all the refrigerant therefore no A/C. Hope that helps!
Old 08-03-2011, 07:54 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Most likely low on charge, will have to take her in to a shop and have them hook the truck up to an a/c machine, make sure if they do recharge the system that they put uv light dye into the system so if there is a leak that it can be traced.
Old 08-03-2011, 08:01 PM
Sledneck's Avatar
Ya you can do that too. Not sure if it will be pricey but I know you can get recharge kits for $40 , comes with a pressure gauge and see if it holds pressure.
Old 08-03-2011, 08:09 PM
Stainless's Avatar
Color: Bright white
Rep:13
I dont rec. people use over the counter a/c recharging equipment, its basically propane which is explosive....most of the kits don't include dye... so you would have to check everything with a soap solution....Redtek does work good, however if you have to take it in to a dealer they are going to charge you big time because you can't recover redtek with a r134 based machine, it makes an azotrope out of the 2 refrigerants and it is very expensive to dispose of. But yes there are cheaper alternatives.
Old 08-04-2011, 05:20 PM
Sledneck's Avatar
oh well there you go!
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 04:59 PM
1992 12 Valve Shock Questions USMCLcpl0311 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 07-20-2011 11:05 AM
Questions about synthetic oil and PCV valve starquestbd22 4.7L PowerTech V8 Specific Topics 4 02-27-2011 11:38 AM
Painting Valve Cover Questions. 98sst Dodge Ram General Discussion 21 11-02-2009 12:20 PM
