P2106 & p2175 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 08-11-2011, 02:46 AM
DannyB DannyB is offline
Vehicle: 2003 Dodge Ram 1500 5.7L Hemi
Color: Blue
DannyB is on a distinguished road
Default P2106 & p2175
I was pulling my trailer with my quad on a gravel road and when i got back on to the highway the red lighting bolt appeared and i lost all my power and the truck started shifting weird. I pulled over and got two codes P2106 and P2175. Has anyone ever came across this problem before? It goes away when i shut it off and sometimes comes back later on but to disappear again when i shut it off. I have a new air filter in it as well. I also have a throttle body spacer if that helps out. From what i have read it is a TB problem. Thanks
Old 08-11-2011, 09:03 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Definitely sounds like a TB issue...I don't know what it could be, I'd start with a good cleaning, then go from there. There should be a TPS and IAC I think those are the only sensors on the TB...
Sean
Old 08-11-2011, 02:23 PM
AndyXplorer's Avatar
AndyXplorer AndyXplorer is offline
Vehicle: 2006 Dodge Ram 1500
Color: Blue
Rep:39
AndyXplorer is on a distinguished road
from what i've read, snrusnak is right. The codes are airflow restriction, and a force into limit mode, which is why it was shifting weird, or it stayed in first gear. The truck noticed you were not getting enugh airflow and limited the amount of acceleration, so you wouldn't damage anything. A good cleaning of your air filter, and throttle body should correct the problem, and from what i have seen so far, the throttle body on these trucks get loaded with crud
Old 08-12-2011, 09:04 PM
lordlucifer's Avatar
lordlucifer lordlucifer is offline
Vehicle: 2003 dodge ram
Rep:23
lordlucifer is on a distinguished road
i had exact same issue , what happened was i broke the iat sensor when changing plug wires, cost 13 bucks from dealership, and new one is alot beefier, iat sensor is plugged into hemi hat , the smallest bump wrong way will make truck undrivable
Xcelerator muffler, custom fab CAI/ ram air system, shorty wires , transgo HD kit, tmr mod
Old 08-13-2011, 12:11 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
that suxs bud but i hope you can get it figured out!!
Old 09-24-2011, 02:34 AM
Color: Blue
Do I need to buy new gaskets if i take the tb out for a good clean or are the re usable?
Old 09-24-2011, 07:59 AM
snrusnak's Avatar
Rep:1388
I'm not positive but I think the first gen hemi TB uses an o-ring as a gasket. If so you could probably reuse it. Let someone else verify that though.
Sean
Old 10-07-2011, 03:53 AM
Color: Blue
Thanks for all your help guys, i took the tb off and cleaned it as it was caked with black crud. It had actually formed a 3/16 lip around the inside of the tb. and the tb spacer i had installed before was covered and the swirl and grooves were full and was not letting the air to spin down properly. Runs great with way more power.
Old 01-30-2012, 04:46 PM
MoparBandit's Avatar
MoparBandit MoparBandit is offline
Vehicle: 2010 Ram 1500 Big Horn
Color: Metallic Blue
Rep:27
MoparBandit is on a distinguished road
THANK GOD FOR SEARCH!!!!!!!!
This has been plaguing my truck since last summer and I was convinced it had to do with how I was applying my foot on the highway till it happened after it just idling in place. My father had his replaced under the 7/70. But it was gonna run me about $300 or so But just tackled the beast to find soo much gunk. To top it off, I took some Semichrome polish paste to really shine it up. Night & day with just the first few miles, smooth idle and stronger pickup now.
2003 1500 HEMI QCSB Black, DSP, 33" BFG A/T's, TOW MIRROR STATUS :P, RECON Smoked Cab Lights
Old 04-05-2016, 10:27 AM
drdodge drdodge is offline
Vehicle: 2004 Ram
Color: blue
drdodge is on a distinguished road
Default stalls on road,, hoping its fixed
Tb took out,, and cleaned,,, I applied some Teflon lub and actually sanded the of edges of the butterfly,, mine could stick shut it was so carbonned up but im not sure that is what happened.. cleaned the sensor, but from the other post I will replace my sensor likely.
it took less than an hour and no new gaskets needed to take the tb off a and clean it,, really would not have to totally remove to partially clean , but it worked well,, need carb or brake cleaner to really clean, I think the sticking closed intermittently is the problem but don't know yet. chevy used to do it also on the manual tb.
