Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Old 08-11-2011, 12:04 PM
boss hogg boss hogg is offline
Vehicle: 2005 ram 1500
Color: silver
boss hogg is on a distinguished road
Default need advice
got a 05 1500 with 3.7 and auto tranny could changing from 245/70/17 to 265/70/17 cause tranny to go in and out of lock-up and besides goin back to 245s what are my options
Old 08-11-2011, 12:11 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
You essentially went from a 31 inch tire to almost a 32.5 inch tire which will make it seem like you have a higher gear ratio. I can't tell you how much of a difference it makes, but it will lower your rpms which may be making your truck trans shift more when encountering slight grades or hills.
Old 08-11-2011, 12:16 PM
CJ.2007Ram's Avatar
Rep:28
Your more expensive option would be to install different gears, but that would definitely be more pof a pain and much more expensive than tires. You could turn off the overdrive function if you have that option also.
Old 08-11-2011, 12:18 PM
Color: silver
thanks i like the 265s i can find them cheaper around here than the 245s and i like the way they look. so do i go to the dealer and get them to change the ratio or what
Old 08-11-2011, 09:05 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The dealer can do that, or if you have a good suspension shop, they can likely either do the gears, or recommend someone that does.
brad
Interested in one of my mods?
Old 08-11-2011, 11:43 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
both answers above are on target!
Advice on first mod since joining! The Codes Dodge Ram General Discussion 7 06-27-2011 11:53 PM
Any advice for better fuel economy? jeremy2011 2011 Dodge Ram Forum 23 06-26-2011 10:05 AM
Advice and Opinions needed! Thrivix Dodge Ram Detailing and General Maintenance Forum 4 11-07-2010 12:22 AM
I am new to this forum, appreciate the advice cscott1537 Newbie Checkin! 11 10-25-2010 07:48 PM
Advice needed from the NW Crew Mountaineer North West 2 09-08-2010 01:39 PM
