Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-11-2011, 12:55 PM
Nailhead Nailhead is offline
Vehicle: 2008 Dodge Ram Power Wagon
Trim Level: Power Wagon
Nailhead is on a distinguished road
Default Power Wagon Sway Bar Fail
I had a problem with the sway bar on my '08 PW yesterday, and I have a few questions about it. First, the tale of woe:
I made a couple full-lock left turns yesterday, and could feel a tire rubbing somewhere. That made no sense-- the tires are the stock size, and besides it was a new development. I gave it a look and noticed the tire had rubbed the sway bar on the passenger side. I didn't think much else of it till I got home, got down and looked, and noticed the pass. side portion of the sway bar had come completely free of the electronic actuator unit, and had worked its way about 1 1/2" out of the rubber bushing.
My neighbor and I put it on his lift, determined the splines on the bar and actuator were okay, indexed it, and put it back together. I was awaiting a call-out to work, so I did not have the time to source a seal & put it back together the way I wish I could have. Sure enough, about 5 minutes before we had it buttoned up, my phone rang.
The securing ring on the end of the sway bar spline was not broken and it seems to want to stay put inside the actuator.
The seal on the actuator is boogered.
My questions are:
What could cause this? I remember entering a parking lot some time ago, and hearing a harsh clank like something gave way, but all felt well, and I didn't notice anything beneath, so I figured the actuator gave way internally.
How is the sway bar removed (again) from the actuator so I can replace that seal? Or can it even be removed? I have this gnawing fear that that whole sway bar assembly with actuator is sold as a unit & is not intended to be (intentionally) disassembled.
And lastly, has this happened to anyone else?
Thanks for any advice.
Old 08-12-2011, 04:30 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top! Hope to see you around!
Old 08-12-2011, 10:12 PM
Thanks for the bump, RR.
I'm beginning to think there isn't an especially broad knowledge base concerning this topic.
Old 08-12-2011, 10:15 PM
RedRam10's Avatar
Rep:743
I know we have several techs here hopefully one will chime in.
Old 08-13-2011, 09:37 AM
Yes.
I'm riding the bike to work right now, mostly for economic reasons, but also so I don't get crud in that actuator.
Thanks.
Old 08-13-2011, 10:19 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
You are right about this being a non-serviceable assembly. If you want to replace the seal, you may be able to find one at a bearing supply place. Taking them the old seal as a sample would be best. As for getting the bar back out of the actuator... . For the most part, your in uncharted waters.
You can view the service manual section on this unit Here.
brad
Interested in one of my mods?
Old 08-13-2011, 01:30 PM
Thank you very much for the info!
Just as I thought-- replaced as an assembly, no user-serviceable parts inside.
This being the case, I think I might just leave well enough alone & not try and disassemble it because I that that might make it even more prone to come apart again.
I will, however, try and find a way to make that seal work a little better. I wish I would have had the time to pull the old one & source a new one, but around here, that could have taken days because such supply houses are so few & far between.
Oh well, if it comes apart again or fails to actuate, I'll replace it. BIG bucks, I'll bet.
Thanks again for the help.
Old 08-13-2011, 01:34 PM
So what about any warranty you may have left?
The individual seal is not a "service part" meaning it is broken down and repaired by the dealer so at the dealer they simply replace the entire assembly.
Sorry, but I have no idea what would cause a failure like this. Is there another part on the opposite side that appears to have been damaged?
Old 08-13-2011, 04:11 PM
I hadn't thought about warranty (I'm still not used to the new vehicle thing), and I don't know if I have any left. What is the warranty period on an '08?
The opposite side looks fine.
Thanks for the suggestion.
2010 Dodge Ram 2500 Power Wagon for sale. 1900 miles WILDMAN Dodge Ram For Sale - Used Dodge Trucks 18 03-28-2012 07:49 AM
Power Wagon is SOLD! Heading to Russia! WILDMAN 2010 Dodge Ram Forum 9 05-18-2011 10:34 AM
2010 Power Wagon Locking diffs question angus66 2010 Dodge Ram Forum 6 12-05-2010 09:28 AM
My Diesel Power wagon fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 10-28-2010 07:06 PM
WANTED: Diesel Power Wagon Quiet Lunatic 2010 Dodge Ram Forum 6 10-16-2010 11:35 PM
