Old 08-09-2011, 06:19 PM
MTHemi's Avatar
MTHemi MTHemi is offline
Vehicle: 2005 Dodge Ram 1500
Color: Charcoal
MTHemi is on a distinguished road
Default Leaf Spring question??
Ok guys I'm new to this so i really don't know if I'm posting this in the right spot.
I got a 3in Rough Country Lift about a month ago and I just installed the Torsion keys to level the front end today looks great! so psyched! we were going to put the blocks in the back when we saw that the leaf springs in the back look like they were overloaded they have an upward bow to them in the middle I'm wondering if i put the lift blocks in, the leaf springs will just bend even more.
IMG_8351.jpg i don't know if you can even see it in the pic
And i noticed that when you look at the back end my rear passenger side tire is slightly more forward then the drivers side we measured and the wheel base is 141 on one side and 140 on the other does anyone know why? I'd rather not get my new 35's until i figure this out!
Old 08-09-2011, 07:00 PM
Rep:1388
Yes something looks off there....I don't think the spring should be bent like that. That could have been caused by overloading or dropping a load into the bed, or jumping the truck..It could probably just be swapped out with new leag springs, however the issue of the screwed up wheel base is more of an issue if you ask me...I'd try to see and make sure the front is square, the figure out what's out of what in the rear, could just be out of whack from the springs being messed up....could take it to a shop that can do alignments and get their opinion as well...
Old 08-15-2011, 05:48 PM
MTHemi's Avatar
Color: Charcoal
Thanks man I'm looking for new springs right now before I put the lift on the rear and I just got some new used nitto terra grapplers 35's I'm gonna put em on next week and get it all aligned hopefully they might have some insight
2wd coil spring spacer question (2009) xploded Dodge Ram 4x4 - Offroad Discussion 2 08-12-2011 04:57 PM
Leaf nd Coil spring spacers 20ramquad04 Dodge Ram Wheels And Tires 3 03-31-2010 10:24 PM
Leaf nd Coil spring spacers 20ramquad04 Dodge Ram Wheels And Tires 10 03-30-2010 10:21 PM
Spring question ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 03-01-2010 09:25 PM
2500 leaf spring blocks 971500 Suspension 5 11-19-2009 05:00 PM
