Old 08-12-2011, 12:59 PM
hutch88 hutch88 is offline
Vehicle: 05 dodge ram 1500
Color: red
hutch88 is on a distinguished road
Default exhust problem
I have 05 ram 1500.i put set of obx headers with full flow resonters on my truck.so no more cats..i have o2 sencers before and after the resonters.my problem is now check engine lite is on for o2 sencers now .how do I fix with out choping my exhust up to put cats back on kit was made for no cats.any help would be awsome thanks hutch
Old 08-12-2011, 01:20 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
try the spark plug non fouler trick for the O2 sensors after where the cat(s) were. Do not do this to the main two O2 sensors that were on the manifolds. Only the O2 sensors that were after the cat(s).... Here: http://www.ramforumz.com/showthread....ghlight=fouler
Scroll to the end there is pics by cheffred...
Sean
Old 08-12-2011, 02:35 PM
Color: red
o2 sencers are already installed before and after the resanters also had to make wires longer for the back two o2 sencers.the code is because there are no cats now.dont remmber what the code was wordfor word hookin back up to buddys scaner later
Old 08-12-2011, 02:37 PM
snrusnak's Avatar
Rep:1385
Right so do the non fouler spacer trick on the rear two sensors. Or are you saying you already tried this? The code is probably P***** "bank 1 sensor 2" and "bank 2 sensor 2"
Sean
Old 08-12-2011, 02:40 PM
Color: red
dont know what that is what r they
Old 08-12-2011, 02:45 PM
snrusnak's Avatar
Rep:1385
click on the link I posted above ^^ scroll to the end of the thread, there are pictures posted by chefred, that's what you need on the two rear O2 sensors.
Sean
Old 08-12-2011, 03:05 PM
Color: red
cool thanks will let u know
Old 08-22-2011, 12:14 PM
snrusnak's Avatar
Rep:1385
hutch, I understand you got your issue resolved, can you post exactly what you did, so I can update another thread I have that pertains to this issue. Mainly I am looking for info on the steel wool part of it... thanks
Sean
Old 08-22-2011, 01:29 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Hold on, the way I read that he had the fake cat sensors before AND after the resonator, as in, had fake cats in place of the O2s you actually NEED to be in the hear and in the ehxuast stream...
Right??
2011 Big Horn 4x4 -SnowWhite-
Old 08-22-2011, 01:35 PM
snrusnak's Avatar
Rep:1385
Right??
________
I think he has long tube headers with upstream O2 sensors, then resonators(fake cats?), then downstream O2 sensors...
The non fouler trick in the downstream sensors should have done the trick for him. I think it didn't work, then he added steel wool in the non fouler and it worked.
Sean
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
Tranny Shifting Problem an4rchy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 03-15-2011 12:07 AM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 12:10 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
