HELP, transmission issue 2004 ram 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 08-13-2011, 07:44 AM
mountaingade mountaingade is offline
Vehicle: 2004 dodge ram 1500
Trim Level: laramie
mountaingade is on a distinguished road
Default HELP, transmission issue 2004 ram 1500
3 months ago I went to the dealer for the 120 000 km tune up for my truck. They did all the required things chrysler asks for for this tune up. The next morning the truck had problems getting into gear especially reverse. It took the transmission about 5 seconds to engage. I called the dealer and they had no idea what was the problem so I did a search on the net and found out that this was caused by bad installation of transmission oil pump seal. After they fixed the seal, the next day, I was on the road going about 75-80 kph and I noticed that as soon as the transmission goes from 4th to 5th gear, you can feel a vary noticeable vibration coming from the transmission and when you give a bit more gas the vibration get's stronger big time and the whole truck shakes until you floor it and force it to downshift, put it in neutral or change gear yourself. This will happen on soft acceleration only. If you accelerate from stop to 100 KPH half throttle you will notice that at every up shift, the rpm's becomes erratic at around 2500 rpm (goes up and down +- 100) for a couple of seconds and then revs up normally. Also, when you put the cruse at about 80 kph and you go up a small hill, when the transmission want's to down shift it hesitates, the rpm goes up about 200 and goes right back down and does this a few times until you are up the hill or going way to slow that is has no choice to downshift. I also noticed that every time I drive the truck for either 20 ft or 100 km, every time I mobilize the truck and still in DRIVE, the rpm's go down to 500 and the engine struggles not to choke until I put it in neutral or give a little tap on the throttle then it goes right back up to 650.
I really need help here, all the dealer are worthless, they all have no idea what is the problem.
They tried the quick learn but no change.
I'm a contractor and need this truck every day.
Thanks
Jean
Old 08-15-2011, 11:23 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top! Drop by the Newbie Checkin and introduce yourself. Hope to see you around!
Old 08-18-2011, 11:30 PM
robustRed's Avatar
robustRed robustRed is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Lone Star PKG
robustRed is on a distinguished road
sorry, i dont have the answer for you either. but if its doing this from the dealer, you should deffinatly get more involved with it and try to get them to fix it. so im gonna ya up to the top to help ya out
2WD-Dsp 93 tune-55 series tires-3.92s-PacesetterLT Headers w/ 3in catted y-pipe- DynoMax Race Bullet- 2.2K ohm power wire- hellwig rear sway bar- 190 Degree Thermostat-
2011 Ram 1500 rust issue dolphinsfan Dodge Ram Warranty Issues 10 10-31-2012 07:41 AM
Transmission or electronics issue? 00SS6spd 5.7L (345 cu in) HEMI V8 Specific Topics 10 11-04-2011 03:44 PM
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 01:45 PM
What lifts would work for my 2004 Ram 1500? CapitanSauce Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 08-03-2010 04:59 PM
Transmission Issue, Slipping and O/D light on gregor413 5.2L V8 Specific Topics 4 05-25-2010 08:42 AM
