Old 07-06-2011, 05:44 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
Default Newbie Racing Questions
For racing on a pretty much stock setup, do you guys have your tow/haul mode on? Also, do you turn off traction control?
And what about manual shifting? If I suck at manual shifting (which I'm sure I do) should I let it shift by itself?
These may seem like really silly questions, but I have a lot to learn!
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 07-06-2011, 05:46 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I just put it in 5 and let the truck do the work! I have no idea either, but I had fun!
Old 07-06-2011, 05:51 PM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Send a message via Skype™ to dwadestrick
When I am playing, I just turn off traction control and shift the truck manually. IMO, I think my truck comes off the line better with traction control off.
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
Old 07-06-2011, 07:08 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
If my understandings are correct it would launch better w/ traction control off b/c the computer would not limit power or delay the transfer from pedal to the truck but if you have enough power you risk losing traction in that case youd have to do some practice at launching to start not just flooring it
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 07-06-2011, 07:15 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I do have the power to spin the tires even with traction control on and without stalling it. But I think if I'm spinning either way, its better to spin with traction control off than on right? I dunno
What about tow/haul mode? Timmy, you mentioned you put it in 5, you can do that without putting tow/haul mode on, so I'm wondering what you mean.
Old 07-06-2011, 09:07 PM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
I could be wrong but tow/haul just keeps your truck from going into overdrive. With your R/T you have a 2600 stall I believe. If I were you I'd go play with launches with revving up to 2400 or so, trac control on and off and feather the throttle to find the perfect mixture. If I were to make a suggestion I would take traction control off, keep your foot on the brake as you rev to 2-2200 rpm and start off with the pedal about half-2/3rds of the way down till you hook up. Using manual shift would be up to you and your comfort level...
Just my .02. Let's hear from the real experts...
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 07-06-2011, 09:12 PM
Traction control off.
Warm up your tires really good before you get to the line.
Put truck in O/D off
Let it shift itself. It's better at it, and faster, than you are.
Old 07-06-2011, 09:23 PM
916Timmy's Avatar
Rep:1443
Freddie (Chefred112)...who runs a 12.38 1/4, told me not to hold the throttle open before launching, the motor will pull timing and will be slower off the line then just smashing it down! You just need to find out how much smash your truck can take without spinning. And I ran my truck in 3 with traction control on. T/C off for the quick burnout, then right back on.
Old 07-07-2011, 12:21 AM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I was messing around a lil tonight and found that the truck seems to shift smoother and take off better with Tow/Haul on and Trac Control off. I upped the RPMs to about 1,800 I think..(I just listen to when its about to spin, I don't actually check the RPMs) and then I took off and my tires only spun for a split second. Then at the next stop light I was on a 10 MPH roll when I mashed in the medal and then I had a hard time getting traction, I was spinning really bad..it was fun
Old 07-07-2011, 12:28 AM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I'm a lil confused about not opening the throttle all the way...can you explain about the motor pulling timing?
drag racing, tow haul mode, traction control
Questions about exhaust (total newbie) titans Exhaust 6 06-22-2011 08:51 AM
Factory Order Questions from a Newbie jhabetler 2011 Dodge Ram Forum 31 05-19-2011 05:14 PM
Newbie questions townsendpn 4.7L PowerTech V8 Specific Topics 2 12-27-2010 04:08 PM
Newbie with questions...and comments. zj4play Newbie Checkin! 11 10-01-2010 01:44 AM
Newbie with questions...and comments. zj4play 2009 Dodge Ram Forum 5 09-29-2010 07:51 PM
