ZDOG
Old 08-14-2011, 08:16 AM
Pud1309's Avatar
Pud1309 Pud1309 is offline
Vehicle: 2010 Dodge Ram 1500 TRX4
Trim Level: TRX4
Rep:57
Pud1309 will become famous soon enough
Default Tire size
I'm Looking to install some 37X13.5R17 tires on my 2010 TRX4. It has a 2.5/1.5 leveling kit, 3" body lift and 1.5" Wheel spacers. I'm curretly rollin' 33x12.5R17 with lots of room and I don't have the body lift installed yet.
any comments or anyone with a similer setup!
Old 08-14-2011, 09:26 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Well,you're adding 4" to the rolling diameter and extra width of an inch. So can you measure a gap of at least 2.5" above what you have at the closest point between the tire and the fender or sway bar? Rough math gives those minimums. If you're going with additional lift you should be ok. Post some photos as you go.
Old 08-15-2011, 11:09 AM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
Where did you get your wheel spacers. I may get a 1/2-3/4" wheel spacer and try to run a 305/70/17 next chance I change out tires from stockers. I've also got the daystar leveling kit so hope that helps. No body lift though.
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 165 02-18-2016 08:35 PM
Determining Speedometer Error Due To Tire Size Change MADDOG Dodge Ram Wheels And Tires 16 01-04-2015 07:33 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire size feature not accurate FDBDW Diablo Predator Questions & Info! 6 01-26-2011 09:05 AM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-21-2010 11:37 PM
