1999 ram won't start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-14-2011, 09:31 AM
Mike G. Mike G. is offline
Vehicle: 1999 Dodge Ram
Mike G. is on a distinguished road
Default 1999 ram won't start
I parked my 1999 ram for a couple weeks. When I went to start it, it turned over, but would not start? It seems to fire briefly, but will not start. I initially thought it was the coil, because I have had to replace it twice already...No luck. Made sure there is enough fuel, added Heet, still did the sae thing. I checked fuel pressure, seems ok(48). What should my next step be?? Any advice is welcome. Thanks
Old 08-14-2011, 04:49 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
How about the starter? How about cleaning off the connections to the starter?
Rain-X Latitude wipers; Volant CAI - with ram air tubing; custom y pipe; Xlerator racing muffler; cats delete HemiFever custom Diablo tune; Line-X; Putco SilverLux LED headlamps; Putco Luminix LED fog lamps; Bilsteins 5100's all around, leveled up front; BFG AT KO 2's; KMC XD Battalion rims
Old 08-15-2011, 07:58 AM
MFitzs70's Avatar
MFitzs70 MFitzs70 is offline
Vehicle: 2007 Ram 1500 5.7 Hemi BigHorn
Trim Level: ? Big Horn ?
Color: Reddish
MFitzs70 is on a distinguished road
Start with the basics....Air,Fuel, Compression , Spark.
Old 08-19-2011, 10:54 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
same thing happend to mine im not getting a spark from my coil im reading other posts and im starting to think it has somthing to do with my starter
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 08-29-2011, 01:52 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Did it rain while it was parked? perhaps the dist cap let a little water in. I'd check the plug in on the coil as well. I've lost several ignition coils too, and am suspect of them straight out of the box, especially of the 90s era Gm and Chrysler designs. I must be simple, for I fail to understand what the starter has to do with the engine being willing to run or not, I have always thought of a starter, working in concert with a few other things, was only responsible for reaching out and grabbing the ring gear and giving it a spin... I keep seeing this starter- no ignition stuff written, would someone clue me in on this? Thanks...
Old 08-30-2011, 04:28 AM
RAMING IT's Avatar
Rep:65
NO rain just freakn died.
Old 09-01-2011, 10:42 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
try to reset the computer. i had a89 dakota started it to move it one day.went to put it back but it would not start. I disconnected the battery and put it in limp mode it started right up.
Old 09-02-2011, 12:07 AM
Color: 1 Blk,1 Red
Rep:36
I agree with the reboot of the ecu. I don't know why, but back in the mid 90s, A respected mechanic told me that when you do this, to have the key turned to ignition, disconnect the neg cable, turn the key off, then reconnect the cable, his logic was that doing it that way dumped the power out of the system capacitors. I don't know if this theory is correct, but it's what I've done when all else fails... The other thing is, are you flooring and holding on the floor the gas pedal?? This is the venerable clear engine position, ecu's are programmed to see this and cut off fuel in the start mode, I have read in many forums, works on carb'd engines, as well... My 98 needs this treatment on occasion in winter time when it's zero and below, it'll start, snort, and die, and will not fire again until I just squeeze the throttle and spin it over. some inaccuracies in my ecu, I guess... Something one lives with... when it does this, it refuses to idle, as well, for a moment or two... perhaps just a quarter squeeze of the accelerator would be worth a try, as well.
Old 09-05-2011, 12:11 AM
RAMING IT's Avatar
Rep:65
My mechanic determined iy was my ecu gone bad so he managed to put one in from another vechile..... it started up but just doesnt run rite u know.... I still have my old one, is there a way of checking to see if it went bad??? How do you put it in limp mode?Thanks guys!!
Old 09-11-2011, 10:39 PM
Color: 1 Blk,1 Red
Rep:36
Limp mode is something the ECU does when it detects certain failures, or lack of proper voltage signals, it's not something you can do to it... I allowed a mechanic to slave the ECU out of my 98 once, it didn't cure anything, and when it was put back in my truck, it ran like poop for about 5 minutes. Ebay was a good source for my 95s new ECU, $20, but it turned out my problem was an erratic fuel pump. You have to have the precise ECU for your truck, 4wd, auto, displacement, and year model, for the 95, it had to be a 2 door standard cab, too, if I remember correctly. theres a 10 or so digit number on a paper sticker that has to match, almost. the tolerance was, the first 4 digits had to be something like 5220 - 5275, or smething like that. (bear in mind this was for my particular 95 model) through deep research at what people are offering on ebay, you can figure out exactly which ECU you'll need. Is your fuel pump pressure steady? having fuel pressure one second, does not mean it always is, I found that out the extremely expensive way, by shotgun troubleshooting, stick your gauge beneath a wiper, and observe it...
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 08:48 PM
Remote start tip snyds 2011 Dodge Ram Forum 3 03-16-2011 09:23 PM
Oil filters by Brand & Manufacturer GTyankee Oil Change 10 04-07-2010 11:34 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 10:27 PM
1999 5.9 gas hard to start sbee500 5.9L V8 Specific Topics 2 09-16-2009 11:25 PM
