1999 ram won't start - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 09-14-2011, 04:26 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Fuel pressure is steady. Can my pickup coil be a result of this mishap?
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 09-14-2011, 11:32 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Air, fuel, spark. Yup, could be... I am truly disgusted by the working conditions one must endure while performing maintenance on the distributor on these machines, must've been sitting at a computer monitor while designing the engine vs firewall relationship on these trucks. If I were you, if you're taking the uncomfortable plunge, I'd bring a new cap and rotor too, and some antiseize for the screws, IF you can even get them out without drilling. whatever happened to spring clips???? (Oh heavens, I'm showing my age again) The good ol 383s, 400s, & 440s had distributors in the front, too... So did the pre 67 318s...
Old 09-15-2011, 09:07 AM
RAMING IT's Avatar
Rep:65
cHANGED OUT THE PICKUP COIL STILL NO LUCK
Old 09-15-2011, 09:25 PM
Color: 1 Blk,1 Red
Rep:36
OK, this is my next angle, does it spin over evenly from cylinder to cylinder on the starter? or does it spin over like a nervous coyote? If it spins evenly from cylinder to cylinder, I would think the timing set was OK, if it doesn't, I'd look at checking the ignition timing to see if it jumped time due to a tired chain or worn sprockets. If I think of other angles, I'll check in, I know exactly how aggravating and expensive this can be, I've been there, when the trouble shows its cause, it'll be forehead slapping time, thats the worst part...
Old 09-15-2011, 09:32 PM
Color: 1 Blk,1 Red
Rep:36
Also, can you set the engine oil dipstick on fire with a match? if so, its flooded beyond belief, and you'll need to change oil, and pull the plugs, spin the motor (ground the distributor end of the coil wire when you do this, or you'll need a new ignition coil, too) put the plugs back in, after clearing the motor, and then maybe things'll be OK...
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 08:48 PM
Remote start tip snyds 2011 Dodge Ram Forum 3 03-16-2011 09:23 PM
Oil filters by Brand & Manufacturer GTyankee Oil Change 10 04-07-2010 11:34 PM
2010 doesnt always start after remote start bigdadsram Electrical 1 12-15-2009 10:27 PM
1999 5.9 gas hard to start sbee500 5.9L V8 Specific Topics 2 09-16-2009 11:25 PM
