Old 08-15-2011, 05:48 PM
Dyoungman1 Dyoungman1 is offline
Vehicle: 2011 Dodge 1500
Trim Level: Big horn
Color: Gray
Dyoungman1 is on a distinguished road
Just got the truck back and they found three recalls after flashing the computer:
11-047: Reprogrammed wireless control module with revised software per RRT 11-047
11-057: Installed foam blocks in both front door weather-strips per RRT 11-057
11-073: Reprogrammed drive train control module per RRT 11-073
They also reported: Battery tests good. Found several loose ground and power connections under hood. Tightened all battery connections. Tightened under hood grounds along both sides of engine compartment near battery and air cleaner. Tightened main ground on engine block left side bottom front and tightened frame ground under vehicle on left front frame rail. Starter connection checked and OK.
Old 11-07-2011, 06:43 PM
Deathrend Deathrend is offline
Vehicle: 2015 Ram 3500 MC DRW
Color: Maximum Steel
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:51
Deathrend will become famous soon enough
My boss is having a similar issue with his 2011 outdoorsman. Just every so often (Three or four days.. to a week) it won't start. They've flashed it, replaced the starter, nothing seems to have fixed it so far. It just went back to the dealership today. Decided to see if I could find anything on here about it.
The dealership is having issues reproducing it, as well as no error codes being shown. It's making it very hard to track down the issue.
2015 Laramie 3500 Mega Cab 4x4 DRW Maximum Steel
Aisin | 4.10 | 5th/Goose Prep | Air Assist | 37,800 GCWR
2013 VW Passat SEL TDI
Need (comfortable) headrest - 2011 RAM 1500 daleoregon 2011 Dodge Ram Forum 15 12-26-2012 08:33 AM
2011 Dodge Ram 1500 Laramie 4X4 kuffs565 Newbie Checkin! 9 08-15-2011 05:10 PM
2011 1500 lift NICERYDZ Newbie Checkin! 8 04-04-2011 12:05 AM
Price on 2011 Ram 1500 C.C. Big Horn jam11 2011 Dodge Ram Forum 23 03-31-2011 10:47 AM
Looking for a 2011 Ram 1500 Crew cab sport price. MitchellBoyz 2011 Dodge Ram Forum 5 03-29-2011 05:01 AM
