Transmission question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-14-2011, 05:33 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Default Transmission question
What kind of horsepower are these 5 speed transmission/transfer cases good to before they need to be beefed up a bit... In fact, who even builds these transmissions and is reputable?
Once the tuners are out for 2011 the FI game is on for my truck and the last thing i want is to bring it up on boost and blow a hole the size of Kentucky in the trans
2011 Big Horn 4x4 -SnowWhite-
Old 08-19-2011, 10:48 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I don't have an answer so, it's time to .................... this back to the top! Hope to see you around!
Old 08-20-2011, 02:01 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
From what ive been able to find out its ~500hp max.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 08-20-2011, 03:35 PM
Rep:2946
I guess it depends on the transmission that you have
Chrysler has its own transmission plant in Kokomo, where they have built most of their automatics. Even the new ZF 8 & 9 speed automatics will be built there
Aisin-Warner has also made transmissions for Chrysler
Getrag has made the standard stick trannys
Dana has made most all the rear ends & transfer cases
Old 08-20-2011, 08:41 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I have less then 500 hp (at the wheels)...and have gone through 3-4 tranny's (I lost count)
Old 08-20-2011, 08:53 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
You also beat on yours all the time racing it. Even a bone stock truck will eventually wear through the tranny if your constantly racing it. The trannies for these trucks were not designed for drag racing and chrysler isnt going to invest millions into beefing up the trannies to be race ready when less then 1% of their customers are actually going to race their trucks.
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 08-20-2011, 08:58 PM
chefred112's Avatar
Rep:656
I take my truck to the track once every 4-5 months (more like twice a year)..don't think that qualifies for racing all the time...but, I do use my truck all the time with over 200k miles on it... when i was lightly modded i didn't have any tranny problems...only started seeing it when I was in the advanced stages of modding...
Old 08-20-2011, 09:13 PM
chefred112's Avatar
Rep:656
if you have 500 hp, your not gonna drive it the same way you drive it when you first drive it off the lot. from time to time your gonna want to use it..that's why we do what we do to build and mod...I'm not worried that i blow tranny's..it comes with the territory. Now I'm doing research to build up my next tranny to the same level i have built my motor up.. so, if your gonna do typical bolt on mods, no worries on the tranny except maybe a shift kit... but if you decide to cam up, fi or spray, should be prepared to upgrade tranny components as well...
Old 08-21-2011, 12:16 AM
Rep:156
Of course, if you built the motor up to 500hp, you will want to use it, BUT, building your motor is just one of the steps when it comes to using that power. All 500 horses needs to be put to the ground by more then just the motor as you know. Some people do forget that when throwing down all that money to make more horsepower.
Old 08-21-2011, 02:53 AM
chefred112's Avatar
Rep:656
i agree..I'm more of a motor guy so i did all I could to the motor...in order to make it easy on the tranny i installed a shift lit and did taller gears (4.56's) to take stress off the driveline components... but as I'm seein the issues i run into, i need to take a closer look at the tranny components and what can be upgraded...I haven't really addressed this because I'm able to get used trannys for free or next to nothing
HELP, transmission issue 2004 ram 1500 mountaingade 5.7L V8 Specific Topics 2 08-18-2011 11:30 PM
2001 Ram1500 5.2 L Transmission shifting problems Mic Shaw 5.2L V8 Specific Topics 12 06-13-2011 08:29 AM
45/545 RFE Transmission Overview RamTech Dodge Ram Knowledge Base 13 02-04-2011 04:13 PM
transmission question fluffyone LD RAM - General Discussion 4 09-19-2010 11:32 PM
Transmission Question 03ramhemi 5.7L V8 Specific Topics 1 10-06-2008 04:58 PM
