Old 08-14-2011, 10:24 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Default Interior LED GURUs help me finish my list!
Here is my list from superbrightleds.com I plan on basically LED everything minus blinkers, because for now I dont 100% the resistor/flasher thing. I just want to make sure I have everything and have 1 question.
1) I used the Sylvania replacement guide list and they only have MAP light no dome light. and I have a 4410 for the map light. Which one is that? It looks like its for the dome light in the back, what do i need for the lights in the front?
2) Also they list an ash tray bulb. Is that the bulb that is shining light down onto the shifter area when the lights are on and is very feint?
3) The LEDs in the mirrors, does anyone know how to get to them? Id love to change the puddle lights to blue
So far here is my list
Ash Tray 1 : 74
Backup lights/Cargo area 4 : 921
High Mount Stop light 1 : 921
Stop Light/Tail Light 2 : 3157
Map Light 1 : 4410
I know Im missing something. I have to be lol. All interior LEDs are blue and all exteriors are legal colors. Id like to do this right the first time. Its basically $100 for everything and i dont want to make 2 orders
2011 Big Horn 4x4 -SnowWhite-
Old 08-15-2011, 02:14 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
ummm as for your first 2 questions im not sure but im pretty sure you cant get into the puddle lights as its all one piece and canr be opened because when mine burnt out the full piece had to be replaced and not just the lights...but im sure some others will chime in on ur questions
Old 08-15-2011, 10:02 AM
CleanCrew's Avatar
CleanCrew CleanCrew is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
Rep:30
CleanCrew is on a distinguished road
These are the lights I used for mine:
Rear dome light 1: http://www.lightdepot.ca/index.php?c...485f86dec77cee
Map lights, glove box & licence plate 5: http://www.lightdepot.ca/product_inf...485f86dec77cee
Vanity mirror 4: http://www.lightdepot.ca/product_inf...485f86dec77cee
Reverse 2: http://www.lightdepot.ca/product_inf...485f86dec77cee
Cargo2: http://www.lightdepot.ca/product_inf...485f86dec77cee
Under Hood 1 (with some solidering): http://www.lightdepot.ca/product_inf...485f86dec77cee
The mirror lights cannot be replaced indavidually, also that little green light that shines down on the shifter is solidered into place & i havent played around with it yet! as far as the ash tray bulb goes, I didnt know I had an ash tray!
Old 08-15-2011, 11:39 AM
SS4Luck's Avatar
Rep:310
One piece as in the plastic housing is one piece and cant be split?
I can get into it and solder new LEDs into it if i can get it apart. Ill pry pull it off this weekend and see what it looks like inside
SS4Luck's Avatar
Rep:310
Thank you so much! Im mechanically sound, but when it gets into little appearance details im a moron
Old 03-17-2014, 04:51 PM
simonmw75 simonmw75 is offline
Vehicle: 2009 Dodge Ram
Color: Graphite
Rep:72
simonmw75 will become famous soon enough
As far as the puddle lights go, you can pry apart. They are only held together by silicon. I have one apart now because i want to change the LED's that shine down. Just can't find the right LED for it. They aren't the same as the ones used in the dash conversion. Could you some help with those.
The LED that shines down on the shifter can be changed. You just have to get to it, grind down the plastic dome and replace the SMD LED underneath it. I did it when i went to blue dash lights.
The INC.500 List Officially Released! America's 500 Fastest Growing Private Companies Justin@AACstyle.com Advanced Automotive Concepts - AACstyle - Dodge Ram Accessories! 9 09-20-2011 12:42 PM
empty friends list harleysarge Off Topic Discussion 17 11-13-2010 05:29 PM
My 2010/2011 List of Mods jayhkr Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 14 12-21-2009 09:42 PM
