Old 08-15-2011, 09:57 PM
easely15 easely15 is offline
Vehicle: 2005 dodge ram 1500
Color: maroon
easely15 is on a distinguished road
Default ebay cold air intake
i was wondering what yalls thoughts were on the ebay cold air intake i know it is not true cold air intake but could any one think of a reason it might hurt something?
Old 08-15-2011, 10:03 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I had one on my '06 with the 4.7 and it worked well. I pulled it off later because I kept getting a vacuume leak code. Put on a K&N and never had the code again.
Old 08-15-2011, 10:22 PM
Color: maroon
thanks man could you tell a differnce in the throttle?
Old 08-23-2011, 12:00 AM
Ram Pants's Avatar
Ram Pants Ram Pants is offline
Ram Pants is on a distinguished road
I had a cheap ebay intake kit on my previous vehicle. I could tell the difference. It worked fine but I also used my K&N filter with it as the filters are usually really cheap as well. The only thing that I think you sacrifice is that the plastic ones do not soak up the engine heat as much as the aluminum ones do. Also, think about it this way, one of my old chevy's had an Airaid brand cold air intake (similar to K&n intakes) and one of the first to market, there intake set up is almost identical to those cheapies on ebay. At the price of those cheap ones, I say go for it.
Old 08-23-2011, 11:00 PM
chrisp chrisp is offline
Vehicle: 05 ram
Color: silver
Rep:12
chrisp is on a distinguished road
i had a cheap ebay one, i had it on for a day and took it off. the filter it came with was a k&n but way to small. my greddy one on my honda is as big if not bigger. my D I C went from 12 mpg down to 10 in one day
Old 08-23-2011, 11:06 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
Ideally, you want a CAI that has a enclosed box and has a smooth tube going from the box to the TB... and of course you want as large as possible filter and ID tubing for the best airflow.
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 08-24-2011, 04:40 AM
2011lonestarhemi 2011lonestarhemi is offline
Vehicle: 2011 Dodge Ram LoneStar Quad
Trim Level: LoneStar-SLT
2011lonestarhemi is on a distinguished road
Why would Dodge make the inlet for the air-box be going into a constrictive fender well? Would it not be better to turn it 90 degrees (counter clockwise-facing the ground) so that is is pulling from a larger volume of air (instead of pointing at the finder well it would be pointing at the ground)? I understand the air could be hotter (since engine and radiator are tangent to the open engine bay, but would the shear volume of air getting to the air-box then the filter/tubing/throttle body be so much more that it would improve air flow? What are the chances of getting vapor lock or sucking up water? (Wouldn't you have to be going through like 2.5-3 feet of water. Doesn't rain that much here in Texas.)
Old 08-24-2011, 09:34 AM
Drake371's Avatar
Rep:83
when idling the air temp will go up cuase no air is flowing into the compartment...with it pointing forward, when you drive you gets fresh air "pushed" in so to speak...if it was pointing straight down, it would get air sucked out and have a loud whistle (blow across the top of a coke bottle).... AirRam does make a scope that forces more are from the grill area into the intake tube from the grill area.
Cold Air Intake & Ram Air Hood? Stonednloaded Body & Interior 1 05-06-2011 02:12 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 10:26 PM
Cold air intake info please E220 2011 Dodge Ram Forum 13 04-15-2011 01:27 AM
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 10:31 PM
