AudioControl LC6i thread.... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-15-2011, 10:34 PM
Lie2me Lie2me is offline
Vehicle: 2011 CC 2wd
Rep:26
Lie2me is on a distinguished road
Default AudioControl LC6i thread....
A friend of mine is having issues with this install, kinda hoping on a guru to help me figure it out. I will also be installing a near identical setup with my factory head unit this weekend. I would really like to skip the learning curve if someone else has experience with this particular signal processor.
"Installed an LC6i and was wondering what would cause mad noise thru the speakers? The subs work fine and the front dash speakers work fine--no extra noise, but when I hook up the 4ch to the 4 door speakers I get a mad noise thru the speakers."
Bad ground? Recheck wiring? reversed polarity? something pinched?
4G Crew Cab
Factory H/U
4 channel amp
sub amp and sub
6 speakers in factory locations.
Any advice is greatly appreciated!
jeff
For the record, its not a hissing noise coming thru the speakers. It just sounds like garbage.
Old 08-15-2011, 11:50 PM
11bigred's Avatar
11bigred 11bigred is offline
Vehicle: 2011 ram 1500 sport
Trim Level: Sport crew cab
Color: Flame red
11bigred is on a distinguished road
Hopefully someone on here has dealt with this setup.......lol,im lost and confused on why i had that awful sound coming out of my doors.
Old 08-16-2011, 12:52 AM
11Ram06Daytona 11Ram06Daytona is offline
Vehicle: 2011 Ram 2500 Mega Cab Diesel
Rep:12
11Ram06Daytona is on a distinguished road
I believe the LC6i has a jumper for the ground just like the LC8i. GND, ISOLATED & 200ohm are your options for the jumper. have your tried moving the jumper to different positions?
Current Mods: Recon Smoked tail lights & 3rd Brake light
By the end of August: Recon Smoked Headlights & Roof Markers, 8K HID, 6" Fabtech Long Arm, Amp Research Steps, Fuel - Gauge 20" Wheels, Bakflip cover, H&S MaxxMini, MBRB Exhaust, 2 10" L7's 1500.1 Kicker amp.
Old 08-16-2011, 01:25 AM
Rep:26
After reading a lot of threads on different sites, I think I see what the main issue is. The 'summed jumpers' are not connected from the factory. This will completely explain the junk sounding signal that is being fed into the 4ch amp for the door speakers.
Another point of intrest is that some people have had problems with the amps making a popping sound when turning on. The LC6i has a remote in and out. To solve this issue, some people have still run the seperate remote(12v) to the amps so they turn on at the same time as the LC6i.
Don't use the same 12v signal for power and remote.
It is also not recommended to use the same ground or power that the factory amp uses. Too many variables involved. It's recommended that you use a 1 amp fuse(current draw is 200ma)on the power. Not sure if the remote needs an amp, but the manual says 1amp, so I will use one just to be safe.
There are also explicit directions on the summing jumper process and the output matching process.
Last but not least, there is quite abit of humor in the factory manual.
Read the manual
Old 08-16-2011, 01:31 AM
Rep:26
I don't think he has tried that...we both assumed that the jumpers were already in place.(I should have read the directions...) As for the ground, haven't even touched it yet. I pulled up the directions tonight and read a few different forums and it seems like this is the issue. I know he's scheduled for back surgery, so I will probablly get mine installed this weekend before he gets a chance to finish his install.
Where is a good place to pull the 12v accessory signal from?
Old 08-16-2011, 06:10 PM
chadzilla500 chadzilla500 is offline
Rep:26
chadzilla500 is on a distinguished road
Hey bigred.. i got your pm but cannot reply since i have only posted a few times on this forum. I have never used a LC6i and am not familiar with it. but if you have a question pm me your phone number and ill try to help you out.
chad
Old 08-16-2011, 10:40 PM
Flat Spot Flat Spot is offline
Vehicle: 2011 Dodge Ram 1500 Sport 4x4
Rep:19
Flat Spot is on a distinguished road
I currently have the LC8i and summing the front dash speakers, including center channel, front doors and the sub. I have the rears by themselves. I don't have any hiss and I do have all the ground wires including those to the amp going to one spot. I left the ground jumper on default settings. I hope that helps.
I plan to sell the LC8i soon as I'm about to swap out the headunit, so I won't need it anymore.
Old 08-16-2011, 10:55 PM
11bigred's Avatar
Color: Flame red
I pulled the 12v from that blue/pink stripe wire that is in the ignition harness.
Old 08-16-2011, 10:58 PM
11bigred's Avatar
Color: Flame red
chad
How did you install your processor?yours is pretty much the same as our audiocontrol,
I will come back to this thread in a couple days,after my surgery.
Old 08-18-2011, 07:05 PM
Rep:26
BigRed, just remove the 4 screws from the cover, move the 'jumper' on output#2 so it will combine #1 & #2. It literally takes about 2 minutes. The instructions are on the inside of the cover. Keep the #3 just like you have it for your sub output.
Good luck with the Surgery, hope it went well!
Jeff
E.L.D. 44's build thread E.L.D. 44 Custom Dodge Ram - Complete Builds 70 08-02-2014 07:42 AM
Black Mamba's Mod Thread Juice420 Custom Dodge Ram - Complete Builds 79 11-06-2012 10:34 AM
2012 Ram Calender Picture Submissions Thread BlueJet Dodge Ram Pictures - Photos 46 09-15-2011 04:05 PM
2011 Ram Calender Picture Submission Thread BlueJet Dodge Ram Pictures - Photos 51 10-16-2010 01:01 PM
Thread Follow up 2010Ramowner Dodge Ram Forum CANADA 3 04-06-2010 12:25 PM
