repower upgrade - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 08-16-2011, 07:11 AM
mayhem mayhem is offline
Vehicle: 1996 ram 2500 2WD ClubCab
Rep:27
mayhem is on a distinguished road
Default repower upgrade
with 110,000 mi. on my '96 2500, it has developed an intermittent knock/rap in the motor that begins at about 2250 rpms. It is loud! I bought this truck 10 yrs ago, and alway do LOFs every 3k at the dealer.
Instead of tearing apart this motor, I'm considering replacing this 8.0 with a SRT/10 motor. I've found several of them available on the internet.
Has anyone done this swap? Does it match up to my tranny? Do I replace the wiring harness? or do I trade the truck in?
Any comments on the knock/rap or motor upgrade would be appreciated.
Thanks
Old 08-20-2011, 10:42 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Wish I did but I don't have an answer so, it's time to .................... this back to the top! Hope to see you around!
Old 08-27-2011, 08:15 PM
Rep:27
The knock has gotten so bad I stopped driving it.
Old 09-25-2011, 06:49 PM
95dodgeV10's Avatar
95dodgeV10 95dodgeV10 is offline
Vehicle: 1995 dodge ram 2500
Trim Level: Laramie SLT
Rep:24
95dodgeV10 is on a distinguished road
sounds like a broke/bent valve hitting the piston or most likely a rod bearing going out. might even be a broken valve spring allowing the engine to run fine till higher rpms till the weakened spring can no longer close the valve fast enough. can you tell the general area of the noise? such as one side or the other or louder at the oil pan or so on
Old 09-25-2011, 06:51 PM
95dodgeV10's Avatar
Rep:24
also an srt-10 swap will require a different computer because the viper motor and truck motor are 2 totally different animals not to mention the difference in age. if your truck is an automatic i highly doubt itll fit your trans, if its a manual it might be more likely
2010 Dodge Ram Alpine RER stereo system upgrade / wiring harness diagrams chadzilla500 Custom Dodge Ram Interior Modifications - Custom Audio / Video 49 04-02-2013 12:03 AM
Kicker Amp Upgrade TedP Custom Dodge Ram Interior Modifications - Custom Audio / Video 4 05-31-2011 02:25 PM
Big-3 upgrade CdnoilRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 13 01-10-2011 11:35 AM
Hennessey Performance Upgrade Bighert3rd 2011 Dodge Ram Forum 9 01-04-2011 09:57 AM
Speaker upgrade Tomhartzelt 2009 Dodge Ram Forum 5 01-26-2010 11:46 PM
