Old 08-16-2011, 12:36 PM
JConnors JConnors is offline
Vehicle: 2006 Dodge Ram
JConnors is on a distinguished road
Send a message via MSN to JConnors
Default Dead fan or Cabin Filter plugged??
Got an issue here and I'm trying to figure it out.
My fan doesn't like to blow..lol. That being said, yea, it's weird. Sometimes it works just fine, you drive for a bit then it appears to stop working, then you stop, rev up the engine and it starts to work again.
It's almost as if it's working on some sort of pressure from elsewhere? I was told recently that if you have a plugged up cabin filter, the fan doesn't work correctly ?
Anyone shed some light on this situation. Thank you.
Also, if there is a cabin filter, I've seen it said it's behind the glovebox. Easy way to take that apart??
Old 08-16-2011, 12:44 PM
RamJet06 RamJet06 is offline
Vehicle: 2012 Ram 1500 Quad Cab
Color: Deep Cherry Red
RamJet06 is on a distinguished road
Sorry I can't help, but I'd be interested in hearing where the cabin filter is myself.
Good luck!
Thanks,
Dave...
Ex-AF B-52 Crew Chief. Daughter is currently active duty, AF Security Specialist.
Old 08-16-2011, 04:05 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
I think the Ram never came with a cabin air filter.
I know i just bought the part to install one in my 2011 Ram.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 08-16-2011, 06:24 PM
Alright, well I guess with that then, where is the fan located ? Behind the glovebox?
Add Cabin Air Filter to 4th Gen for less than $20 HoustonHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 184 02-22-2015 06:25 PM
How to change cabin air filter in 98 Ram? DaSOB Dodge Ram General Discussion 2 10-12-2009 10:38 PM
In cabin air filter Short bed 04 Interior Cleaning and Maintenance! 3 08-25-2009 12:38 AM
Cabin air filter ernsppw Dodge Ram General Discussion 0 07-14-2009 12:24 PM
