Old 08-23-2011, 12:44 PM
Vic842's Avatar
Vic842 Vic842 is offline
Vehicle: 2000 Dodge Ram 1500 5.9L
Trim Level: SLT Laramie
Color: Maroon
Vic842 is on a distinguished road
Default Update
So... The only thing that doesnt work now is the intermittent wipers, and the wipers dont come on when I hit the wash windshield button... The wash button does spray washer fluid tho...
Ideas?
I also checked all fuses at end of dashboard and they are good...
Old 08-23-2011, 11:38 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
This is sounding more and more like a CTM problem.
First things first. Locate the CTM. It will be under the dash on the drivers side to the right of the steering column. It is held in with 2 screws to the metal, vertical lower dash support. There are 3 versions of this module. Since your truck is a Laramie, I am willing to bet it is version 2 or 3, which will have 2 wiring connectors. One of these has 14 pins, but only 12 wires, the other has 18 pins with 16 wires.
The smaller of the 2 is the one we're interested in. It has all the wiper functions plus the sense circuits for the drivers and passengers doors, and the key-in-ignition sense.
Check to ensure this plug is fully seated. Better then that, unplug it, and re-plug it back in, which will cycle the contacts to help ensure proper electrical connection.
If everything miraculously starts to work.. ... If not, find a volt meter and check from vehicle ground to the red wire (should be right at the end of one of the rows of wires) for 12volts. It should be there whether or not the ignition is turned on.
After that, check the (Dark Blue) and the (Dark Blue with white stripe) for 12volt power only when the ignition is on. These 2 wires should be right beside each other and near the middle of the row with the red wire.
brad
Interested in one of my mods?
Old 08-24-2011, 03:42 PM
Vic842's Avatar
Color: Maroon
Default Not so Miraculous...
Hey Brad and everyone else who may be looking for an answer on the above issue...
Tricky solution...
First off thank you to Brad for helping out huge, stuck with me step by step to conquer this bad boy...
Replaced my Multi switch with a brand new one... (Still no fix to anything)
After I checked my Washer Fluid pump and realized it was unplugged (plugged it in) had washer fluid spraying...
I am not one that knows anything of what I am looking at when I look under my dashboard... (Bad with electricals)
Brad steps in and tell me where to find the only other problem my washers could have... The CTM (Found at a dealership for $125 usually)... Brad tells me where it is under my dashboard, I go and take a look...
ITS UNPLUGGED!!!!
PLUGGED IT IN... EVERYTHING WORKS GREAT...
Moral of the story is... Before you go buy parts, make sure all your connections are plugged in that are part of the inoperable system...
Thank you Brad
I'm a bonehead... You cant make this garbage up...
Old 08-24-2011, 10:47 PM
brad12kx's Avatar
Rep:2581
I'm so glad to hear you have everything working properly.
These trucks are always a pleasure to drive, and even better when everything is working.
brad
Old 04-26-2012, 09:28 AM
sasquatchram sasquatchram is offline
Vehicle: 1998 1500 4x4
sasquatchram is on a distinguished road
Wanted to bump this back to the top as a lesson in reading through the archives. I had all the symptoms Vic842 was experiencing. Checked the CTM plugs and it was unplugged too. Fixed without spending a dime...
Old 04-26-2012, 09:43 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
I think the washer is conroled by conrol modual ind I think its in kick pannel on left side.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Intermittent Wiper issue crazygreek89 Electrical 2 04-30-2011 10:43 PM
Shifter Display on console & Intermittent Wiper Issue Megaman Electrical 1 10-19-2010 09:44 AM
Windshield Wiper Problem galaine57 Cummins Diesel Specific Topics 4 09-20-2010 12:43 PM
