Old 08-29-2011, 05:35 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I have two friends with lifted 4wd auto trucks. One is chevy and one is gmc though. Both do some serious offroading. Neither of them have had any issues.
Dillon-aka, The Little Kid
Old 08-29-2011, 05:45 PM
llsht14's Avatar
llsht14 llsht14 is offline
Vehicle: 2015 Ram Power Wagon
Rep:25
llsht14 is on a distinguished road
Originally Posted by BigHorn 4 Life View Post
Ok well that is not what BDS told me. They told me if you have a 4x4 auto you might have to replace the front diff to make it a regular 4wd.That is what I was told.
Huh, well i guess either could be correct, all i know is i dnt have a vibe and im OK with that haha
2011 Ram 2500 Laramie Megacab Cummins, afe intake, h&s egr delete, flo pro 5" turbo back exhaust, 6 in tip, mini maxx tuner
Sold--- 2011 Ram 1500 Sport
Old 08-29-2011, 05:53 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
only the transfer case is different, Both systems are regular part time "4WD"
The front differential and CV shafts are ALL the exact same part#'s for both.
Its a simple electronic activated clutch inside the optional transfer case that engages the front drive shaft when rear wheel slip is detected when you're in 4WD Auto mode.
You Do realize the Rams with the optional 4WD Auto still have 4WD Lock (4Hi) right?
if the front differential was a totally different awd trans axle set up like an AWD car, then you would not still have a 4WD Lock option for the transfer case
The trucks with 4WD Auto "option" operate identical to the NVG 246 Transfecase without the 4WD Auto setting when using 4Hi/4Lo
Old 08-29-2011, 06:11 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
I used spacers, had an alignment...still some low speed vibration...
note: my dealer didn't want to do the alignment on a lifted truck...only have 2.5 inch lift,
took it to "4 wheel parts", they did a great job
So it is written ! So it shall be done!
Old 08-29-2011, 06:20 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
My dealer did my alignment and my truck drives awesome. I have an 8" lift with 37's.
Old 08-29-2011, 06:50 PM
llsht14's Avatar
Rep:25
Mines bigger lol ok im done pickin now
Old 08-29-2011, 07:09 PM
Rep:463
Don't thinkso .
Old 08-29-2011, 07:36 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
holy thread jack goin on here!!!!!!!! so bighorn you got it taken care of?
Old 08-29-2011, 08:02 PM
Rep:463
Mine has been fine from day one bro.
Old 09-02-2011, 02:49 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
After reading several of these threads, it sounds like a lot of people that get the Bilstien 5100s end up with a wobble/vibration at low speeds, sub 15mph, in 4wd only, not in 2wd correct? It also sounds like no one knows the cause or fix for it and that not everyone has it? Doesn't that seem a bit odd to anyone?
If i can kill it with an arrow, I'll eat it.
Bilstein 5100 install. Pic heavy. 2011 ram 1500 shelby78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 38 11-12-2013 10:37 PM
Bilstein 5100 leveling for 2011 RAM Dyoungman1 2011 Dodge Ram Forum 18 05-18-2011 04:35 PM
Bilstein 5100 shocks problems... mmalloy 2009 Dodge Ram Forum 12 04-23-2011 01:26 PM
Leveling Kit vs Bilstein 5100 1stram10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 26 12-09-2010 02:04 AM
Bilstein 5100 Leveling Shocks Question - 2010 Ram 4x4 FormerGorilla Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 09-28-2010 02:24 AM
