vibes in 4x4 after bilstein 5100 install - Page 8 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-07-2011, 06:42 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Guys! Pretty sure that if you switch to a high angle cv joint, (KORE),you could jack your truck to the moon without any vibration problems. Good luck!
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 12-07-2011, 08:46 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Well I have a 6" lift with bilsteins set at 2.8" and I have very little vibration 0 to 15 mph. If I didnt put the cv's in I will still be ok. So if I do it I will be better then ok but if I dont it wont hurt anything either. I dont plan on going any higher either. I can barely get in it now with my steps lol.
Old 12-08-2011, 02:23 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
No vibrations on my lift
[CENTER][SIGPIC][/SIGPIC]
Old 12-09-2011, 05:16 AM
Rep:463
Well the day i tried my 4wd after the bilsteins were installed I must have been on a bumpy road or something. Tried it this morning going home from work and no vibration in 4wd . I locked it in at a stop sign and went about 1/8th of a mile no vibrations. I took it out and when i was almost home doing about 10 mph i locked it in again and no vibration. I am happy now .
Old 12-18-2011, 11:23 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
thats sweet bighorn but i wish mine never had it but i really need to figure out if its a driveline vibration or if its my tires not balanced correctly cuz its wintertime now and the roads dont get plowed as much as they should and the slight vibration is driving me nuts
Old 12-18-2011, 11:31 PM
Rep:463
I would start wit tires. Then if its not the tires go from there. Even if you do have a vibration it wnt hurt it I wouldnt think.
Old 12-19-2011, 01:32 AM
954rrmike's Avatar
954rrmike 954rrmike is offline
Vehicle: 2014 Ram Sport
Trim Level: Sport Crew Cab
954rrmike is on a distinguished road
Is this vibration only in 4x4 on dry pavement?
2014 Sport Crew Cab White,8 speed 392LSD,LineX bed liner, Mufflex DOD24M, 18" xd monsters with blizzaks, weather tech floor liners and mudflaps
Old 12-19-2011, 03:15 AM
BJPUSMC's Avatar
BJPUSMC BJPUSMC is offline
Vehicle: 2013 Ram 2500 Mega Cab 4x4
Color: Deep Cherry Red/ Silver
BJPUSMC is on a distinguished road
Hey BigHorn,
The Bilstein 5100's are on my list of mods upon return stateside to level out my truck. Do you think that our existing 6" lifts with thier CV angle adjustments are mitigating the problems with the woble? Seems like all the issues occur when used level stock trucks unless I am missing something.
2013 Ram 2500 Laramie Mega Cab 4x4,
6.7L H.O. Cummins Turbo Diesel
USMC Pilot
Old 12-19-2011, 01:12 PM
Laffs Laffs is offline
Vehicle: 2006 Dodge Ram 1500 4x4
Rep:39
Laffs is on a distinguished road
I would think you guys with 6" + lifts might be mitigating the problems because those kits usually drop the front diff do they not? And the cause of the vibrations are the CV angles.
I have a 2" truxx kit in mine and it shakes pretty good under mild to hard accel in 4x4. Got to investigate further, but its looking like im getting custom mounts made to drop the diff or buying KORE CVs as i want it fixed. Then the arguement is if I'm going to spend $800 on KORE CV's why not spend $1000 on a 6'' Lift instead...
Old 12-19-2011, 02:05 PM
rinkerman rinkerman is offline
Vehicle: 2010 Crew Cab
rinkerman is on a distinguished road
Would really like to get my truck level & use the Bilsteins but don't want to get the vibrations. Anyone recommend any good shops in the Chicagoland area?
Bilstein 5100 install. Pic heavy. 2011 ram 1500 shelby78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 38 11-12-2013 10:37 PM
Bilstein 5100 leveling for 2011 RAM Dyoungman1 2011 Dodge Ram Forum 18 05-18-2011 03:35 PM
Bilstein 5100 shocks problems... mmalloy 2009 Dodge Ram Forum 12 04-23-2011 12:26 PM
Leveling Kit vs Bilstein 5100 1stram10 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 26 12-09-2010 02:04 AM
Bilstein 5100 Leveling Shocks Question - 2010 Ram 4x4 FormerGorilla Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 09-28-2010 01:24 AM
