Need Expert Help. Front Right Suspension - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-17-2011, 03:57 PM
JustoneProblem JustoneProblem is offline
Vehicle: 2003 Dodge Ram
JustoneProblem is on a distinguished road
Default Need Expert Help. Front Right Suspension
My Friend and i were cruising down a creek bottom and hit a bad hole at about 15 MPH. We stopped to check the damage to his truck and the front right of his truck was sitting just above his tire. First thought was that it was a blown shock absorber, it wasnt. The previous owner had lifted the truck by cranking the torsion bars up, we replaced the lower cntrol arm and still no fix. The right side torsion bar is hella loose but cant figure out how to tighten it. Any Solutions are greatly appreciated.
Old 08-17-2011, 05:57 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
You need a special tool to tighten torsion bars. check to make sure shock/spring mounts are busted
2011 Big Horn 4x4 -SnowWhite-
problems, suspension, suspension leveling
Front Driveline Question herc 2011 Dodge Ram Forum 7 04-19-2011 04:35 PM
Squeaking front suspension, turning and bumps Lockard191 Suspension 3 03-25-2011 07:04 PM
Bilstein 5100 / Roadmaster Active Suspension ram1hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-09-2010 05:57 AM
Front Suspension TerryXn9 LD RAM - General Discussion 3 02-09-2010 02:36 AM
Noise in front suspension 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 12-18-2008 09:59 PM
