Old 08-17-2011, 06:25 PM
thevike93's Avatar
thevike93 thevike93 is offline
Vehicle: 2011 Ram 1500
Color: Grey
thevike93 is on a distinguished road
Default 2 questions for new 2011 Ram owner
Just purchased a new 2011 SLT Quad Cab. There's enough information on this forum you could spend days looking at it (I guess more is better than not enough).
I've got a couple questions I'm hoping someone can shed some light on.
First, I've noticed that I can feel the road on the accelerator, mostly just small bumps and patterns in the road. I've never felt this in other trucks that I've owned. Is this normal?
Second, what is the "break in" period on these 5.7 Hemi's? I've got around 1,000 miles on mine and I'm still hesitant to kick it down.
Thanks in advance.
Old 08-17-2011, 07:32 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Welcome to the forum!
1) Do you mean you feel the bumps in the road through the gas pedal? These trucks are DBW (drive by wire), and contrary to how it sounds do not have a throttle cable, they are driven electronically. So any vibrations you are feeling would simply be coming through the dram of the truck to the body.
2) All the engines Ive had before I run easy to 1,000 miles, change the oil, and then its game on! Im sure other will say something different, but that is my plan with my 2011
2011 Big Horn 4x4 -SnowWhite-
Old 08-17-2011, 10:23 PM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
1) i feel the vibration in my accelerator pedal as well, though it does not feel like it's associated with the road so much as it's associated with the engine (or some other piece of rotating equipment). i've seen other threads on it, so i suppose it's typical.
2) from the owner's manual:
A long break-in period is not required for the engine and drivetrain (transmission and axle) in your vehicle.
Drive moderately during the first 300 miles (500 km). After the initial 60 miles (100 km), speeds up to 50 or 55 mph (80 or 90 km/h) are desirable.
While cruising, brief full-throttle acceleration within the limits of local traffic laws, contributes to a good break-in. Wide-open throttle acceleration in low gear can be detrimental and should be avoided.
p.s. i romped on mine occasionally during break-in . there's two schools of thought: baby it during break-in, and drive it like you stole it. i was somewhere in between.
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 08-17-2011, 10:27 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
After 1000 miles just make sure it is up to operating temps then go have fun. IMHO
Old 08-18-2011, 12:33 AM
chuckie chuckie is offline
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
chuckie will become famous soon enoughchuckie will become famous soon enough
I switched to mobil1 oil at 1,000 miles
Old 08-18-2011, 01:31 AM
foothill foothill is offline
Vehicle: 2011 Ram
Trim Level: 1500 Laramie Crew
Color: white over silver
foothill is on a distinguished road
I have been having so much fun driving my new truck I forgot that I should be "breaking it in". Heck, I have been stomping on it! Gottal love that Hemi speed and sound!
Old 08-18-2011, 02:21 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Originally Posted by thevike93 View Post
.... I've got around 1,000 miles on mine and I'm still hesitant to kick it down.
Stop hesitating and let the reigns loose. The Hemi was ready by the 300mile mark, and the differential gears were hardened enough by 500 miles, so enjoy your Ram!
2 important things to remember -
1) If your truck is stock form, the electronics go a long way to ensure you can't do anything harmful....but use some discretion. If it breaks - WARRANTY!
2) Most Law Enforcement Officers frown on you having too much fun with the Hemi....again, use discretion.
brad
Interested in one of my mods?
Old 08-18-2011, 07:31 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
According to other owners, the vibration is coming from where the cable comes through the floorboard. It doesn't bother me so I've never checked it out to see how it is designed. If I remember correctly, they installed a hose where the cable comes in and used silicone to hold it in place sucessfully getting rid of the vibration. You can check it out for yourself if you're up to it, it's the cable vibrating against the hole. I'm sure you could figure out the fix once you see it for yourself...good luck. As far as breakin, I don't even think it would hurt to pull a couple of gears straight off the floor. Actual breakin for seals and seating would take a few thousand miles. So don't be surprised if you see a small puff of smoke or two during that time when you crank it up, mine did and it eventually went away.
Old 08-18-2011, 11:27 AM
thevike93's Avatar
Color: Grey
Thanks for all the great info, and piece of mind on the break in period. I went from an 08 Chevy to the Ram.
For anyone that knows hwy 63 from Rochester, MN to Lake City, MN. I can definitely tell the difference pulling our boat with the Ram compared to the 5.3 Silverado. Piece of cake for the Ram. I can't wait to make a trip up to Ontario with this truck.
Old 08-19-2011, 01:57 PM
Sirchris Sirchris is offline
Vehicle: 2011
Trim Level: Tradesman
Color: Midnight blue
Rep:24
Sirchris is on a distinguished road
Break in? Dang! I knew I forgot something. I've heard you're supposed to drive/ run a new motor in a variety of speeds/ rpm's. Run it slow, get on it, etc..
The World According to Chris is a Perfect Place
2011 Sport Questions mineralram 2011 Dodge Ram Forum 6 05-16-2011 10:09 PM
New Ram owner with Questions bennny Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 3 04-27-2011 10:27 AM
New Owner Questions jmaenner Newbie Checkin! 15 04-25-2011 07:21 PM
HELP - New 2011 Big Horn 4.7 V8 Owner bastien23 Newbie Checkin! 11 04-23-2011 09:15 PM
Couple questions Quiet Lunatic Electrical 4 09-11-2008 07:45 AM
