Old 08-23-2011, 04:58 PM
Gen1dak Gen1dak is online now
Vehicle: 1990 RamCharger
Rep:85
With a 4" stroker crank a 318 bored .030 over yields 390 cubes. The 360 with 4" stroke yields 402, 406, and 408 depending on bore: stock 4.00, 4.020, 4.030". The 340 has a stock bore of 4.040", and yields 410". MP offers this combo in new 340 R3 blocks. A 340 taken .030 over with 4" stroke yield a 416. Keep in mind that stock Magnum heads support roughly 400hp. Both the 318 and 360 have nailed just over 400hp at 6,000rpms with same heads, intake, cam so you should consider this. A stroker would be a torque monster, but will max out the heads at slightly lower rpms. You can partially overcome this with forced induction, but unless you're going to pop for aftermarket heads or major work on the stockers (or a blower) you won't see much over 400hp, regardless of engine size.
Old 08-25-2011, 05:25 PM
crip crip is offline
Vehicle: 2000 dodge ram 1500
Color: green
crip is on a distinguished road
^^great info was just going to ask question pertaining to this. i have a 5.2 and was wondering what you can get out of them with work and have it somewhat reliable.
Old 08-25-2011, 10:08 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
i think a 318 can be built into a 390 stroker. i could be wrong but im pretty sure thats right
Old 08-25-2011, 10:11 PM
mr.lopar's Avatar
Rep:192
just read Gen1dak already noted that
Old 08-26-2011, 12:34 AM
mr.lopar's Avatar
Rep:192
now yall got me lookin up stroker kits for my truck, as if i need to dump more money into it
Old 11-03-2011, 07:15 AM
bigmikelrg's Avatar
bigmikelrg bigmikelrg is offline
Vehicle: 1999 Dodge Ram 1500 Sport
bigmikelrg is on a distinguished road
So will I have to buy all of this off of this kit ( http://www.moparproshop.com/inc/sdetail/4383/4484 ) or just the crank then like Gen1dak said get aftermarket heads to make sure I'm safe or will I have to get this kit with pistons and ect.?for my 318?
HyperTech Power Programmer, PowerAid Throttle Body spacer, BOSH Plugs, Super40 FlowMaster Exhaust
Old 11-04-2011, 01:00 AM
Rep:85
Have to go full boat, pistons too. The longer stroke can cause piston skirt clearance issues with the stickers. Also, since the block will also have to be bored out, the pistons are bigger too. You get the idea. Doesn't hurt to have the stronger aftermarket jobs anyway since you're pushing for more HP. Also, with a stroker, you will need the longer rods in the kit. Mopar stockers are stout, but the added length is necessary and the added strength is absolutely vital in the stroker setup.
Old 11-04-2011, 02:56 AM
bigmikelrg's Avatar
Yes very helpful but is there a cheaper way to stroke then just buying the kit Donizetti rly need all those parts
Old 11-04-2011, 02:58 AM
bigmikelrg's Avatar
I mean do I rly need all the parts in the kit or can I buy justva couple exes and save myself a couple bucks..lol I am on a budget wat do u suggest?
Old 11-05-2011, 12:44 AM
Rep:85
Agreed, there are cheaper ways, albeit with lesser displacements. A stroker crank with longer rods can be done. Don't overbore and the stock pistons can be retained. The piston skirt clearance should be checked. Still, stroker and budget seldom go together. The kits cost more, but the homework is done. Piece it together and it may cost you more in the long run.
witch is worth it $$ wise a 390 or 408 stroker White Lightening Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 10 07-31-2011 05:01 PM
Cerwin Vega Stroker 15s and Diamond Audio D5 5.1 amplifier chithead Miscellaneous For Sale 7 02-15-2011 12:32 AM
stroker kits moparmike07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 10-20-2010 11:00 AM
408 stroker gutless grumblefury Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 38 10-16-2010 01:20 PM
