Old 08-18-2011, 05:34 PM
Lunatic Fringe Lunatic Fringe is offline
Vehicle: 2002 Dodge Ram
Rep:21
Lunatic Fringe is on a distinguished road
Default What Did I Mess UP? (Cooling System)
So I just did the plenum repair and that actually went quite well. I'm embarrassed to say that I'm having problems getting the radiator cooling system to fill though. Seems like it should be easy but I'm scratching my head on this...
Part of doing the plenum repair is draining the radiator which I did. To get all the coolant back into the system my manual says to fill the overflow tank, turn on the heater to high and start the engine. The t-stat is supposed to open when the engine gets hot enough and the mix in the overflow tank will circulate and the level will drop when it does. The problem is that it doesn't seem like the t-stat is opening and the coolant level in the overflow tank never changes. The upper radiator hose doesn't seem to fill with coolant. I know that the system is well over a gallon short of full.
What am I doing wrong?
TIA,
Bob
Old 08-18-2011, 06:57 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
TIA,
Bob
You're suppose to fill the radiator with a 50/50 mix then start the car and put the heat on high keeping the radiator cap off, I find it best and makes things quicker if you put the cap on and squeeze the top radiator hose as it pushes air out and allows coolant to travel in the hose to the thermostat if their isn't enough water on top and bottom of the stat it takes for ever to open and sometimes never opens this has happened to me before. Anyways put 50/50 mix in the radiator then turn the engine on let it run and slowly add the mix to the radiator as the level goes down then seal off the radiator by putting the cap on then top off the tank. Next squeeze the top hose a few times and you will see air escape out the reserve tank, then drive the vehicle see if it overheats then when you get home if it didn't over heat or seems to be a little hotter than usual just go home let the radiator cool for a couple hours then slowly open the radiator cap to let the air out then put the cap on and top off the reserve tank if needed.
This usually works well for me makes things quick cause I have had so many air locks especially since I have a conversion van and well it has rear heat so their are two heater hoses running like 15 feet to the back of the vehicle to the rear heater core. So anyways just try that it works out for the best.
Old 08-19-2011, 03:51 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Yeah what you need to do is fill up the radiater with 50/50 until you cant anymore, and then let the vehicle run, you'll be able to tell when the t stat opens, and then you can put more in, thats what i did, when i put the water pump on my truck!
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
430 Media System HDD issue maggiebowtech Newbie Checkin! 9 06-13-2011 11:10 PM
Anybody ever use any stop leak in their cooling system? albow Dodge Ram General Discussion 17 06-09-2011 12:24 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
A/C Actin Up... Some help please ScatPak07 Heating & Cooling 7 06-03-2010 08:00 PM
