Tow/Haul - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-18-2011, 11:05 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:38
ND RAM is on a distinguished road
Default Tow/Haul
If I use this mode, should I just let the transmission shift normally or should I shift it "manually" like I do without the Tow/Haul turned on?
I'm thinking it will lock out 5th gear. I imagine it will change the shift points in the other gears.
It looks like the "traction control" default is "On". Pushing the button shuts it "Off".
I'm learning slow but sure. I've had the truck since early April and only have 2300 miles on it.
The more I drive it the more I like it. I REALLY have to watch it around town as 40 mph comes up pretty easy.
Got to love that Hemi with 3.92's.
18" Magnaflow, AVS Vent Visors, Black Rectangular Running Boards, Access Lorado Box Cover, Access Bed Mat, W.Tech Mud Flaps, W.Tech Tailgate Tech Liner, Hitch/Hook, Hitch/Ball and 35% Front Side Windows Tint.
Old 08-18-2011, 11:43 PM
sxthemicrewcab's Avatar
sxthemicrewcab sxthemicrewcab is offline
Vehicle: 2011 dodge ram
Trim Level: sport
sxthemicrewcab is on a distinguished road
you cant change gears manually in tow hual, i have tried and it doesnt do anything.
Mods: diablo sport trinity t1000, total load control airbags
Old 08-19-2011, 01:43 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
The + and - on your shifter is not for manually shifting the truck (although I wish it was). That system is more of a "gear limiter". For example, if you are in 3rd gear and hit -, the truck will shift down and then not shift up, you've essentially limited the tranny to 2nd gear. It would still shift down to 1st, but again, it would not shift to 3rd. Maybe you know this and that is what was meant by "manually".
In response to the original issue... yes, you can let it shift normally. I have limited my truck to 4th before, but that's only when I have a large trailer in tow and maybe going through a hilly area that way the tranny isn't being overworked by shifting up and down so much. Also, tow/haul, with the rpm shift points changed, seems to provide much better engine braking when towing a large load. That's always a plus in my book.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 08-19-2011, 02:02 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Shifting manually does not limit the gear. The truck will shift if it hits rev limiter so you don't mess up the truck even in manual mode
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 08-19-2011, 02:26 AM
Rep:147
It does limit the gear under normal driving conditions. The upshift you speak of is simply a protection, and you are right the truck will do that. Unless racing or something similar, you shouldn't be redlining anyway. Still, yes it is meant as a gear limiter.
Old 08-19-2011, 11:01 AM
philpott50 philpott50 is offline
Vehicle: 2015 Ram
Trim Level: Rebel
Color: Red/Black
Rep:49
philpott50 is on a distinguished road
I use mine manualy when going steep hills. I shift down to keep from riding my brakes all the way down. Also if you want to get out of manual just hold the shifter over to the plus for aobut 3 seconds it will go back to auto while in tow haul and not in tow haul.
Old 08-19-2011, 04:57 PM
pall2509 pall2509 is offline
Vehicle: 2001 Dodge Ram
pall2509 is on a distinguished road
mine works in tow haul
grinding noise while tow/haul engaged? Pigpen 2011 Dodge Ram Forum 9 09-06-2011 08:04 PM
Tow/Haul mike56 Towing 11 08-23-2011 04:57 PM
Tow/Haul and ERS, what are the differences? junior1967 2011 Dodge Ram Forum 2 04-20-2011 11:29 PM
Tow/Haul mode or no? SvB4EvA Drag Racing Discussion 11 11-28-2010 03:48 PM
Tow/Haul Mode BlueLightning 2010 Dodge Ram Forum 25 08-11-2010 12:40 PM
