Old 08-19-2011, 05:47 AM
jandrso jandrso is offline
Vehicle: 2011 Ram 1500
Color: Forest Green
Rep:13
jandrso is on a distinguished road
Default 2011 Laramie 1500 towing 9000lbs.
What should I expect? It is rated for 10200 lbs. I got all the towing req's when choosing the truck then bought it. Now I am in the market for a travel trailer.
The one I have my eyes on is 7600 dry and 9900 loaded to the gills. I figure to be around 8800 average weight.
The Ram 1500 won the "truth" test when I shopped for the truck. Now I need real work experiences........
2011 Laramie1500 HEMI:UConnect730n:Cooled Seats:Rear Entertainment:Class IV Hitch:Born 10/5/2010 5pm
Old 08-19-2011, 10:51 AM
philpott50 philpott50 is offline
Vehicle: 2011 Dodge Ram
Color: Rugged Brown Pearl
Rep:49
philpott50 is on a distinguished road
I have pulled an 8000 pound travel trailer with mine up through the ozarks of Arkansas and Missouri. No problem pulling. I had the swaybar with torsion bar system set up to. If you don't put the torsion bars on you will sag big time. It will pull it but it is real light up front and makes it dificult to drive.
Old 08-19-2011, 07:15 PM
Skidoo Dad's Avatar
Skidoo Dad Skidoo Dad is offline
Vehicle: 2011 Ram Crew 4x4
Trim Level: Outdoorsman
Skidoo Dad is on a distinguished road
no air bags ? Will you install them ?
Old 08-19-2011, 11:37 PM
Appaloosa Appaloosa is offline
Vehicle: 2012 Ram 3500 4X4
Appaloosa is on a distinguished road
I have pulled about 8000 with my 1500 It handles it well as far as power... gas mileage goes down but its working so... I installed Timbren SES on the back to allow for the soft springs. It rides good loaded and empty.
Old 08-19-2011, 11:43 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
The tires that come on these 1500 trucks are not designed to handle heavy loads and especially trailering. I trailer heavy loads at times and swapped mine out for E rated LT's of the same size. The difference is night and day and makes the truck feel safer while towing. They are inflated to the factory 40 lbs and ride fairly comfortable considering. I can inflate them to 80 lbs if need be but have never had to. My truck now handles like a rock when cornering with a load behind me, it's nice and firm and feels made for the job. Prior to the change it felt like it wanted to go straight and it would try to over and understeer. I use both terms because some will argue the meaning. It did both because of the spongy sidewalls. With the old tires, you could grab my truck on the rear and shake it side to side it pretty bad. Try to do the same to your trucks by shaking the rear side to side and you will see what I'm talking about. After the change, you can not budge it. You have to change all four tires and not just the rears...that is a must do. You are doing the job of a 3/4 ton truck, so it would be best to dress it up like one.
Old 08-20-2011, 05:40 AM
Color: Forest Green
Rep:13
Thanks for the info folks. Just too let you know was thinking about airbags post hookup inspection. The tires however I did not think about. I will Start pricing them out.
We are not getting the trailer until February or so and definitely not till the Truck is ready for it.
Still, love the truck!
2011 Ram 1500 Laramie Dash Removal rhgusman Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 05-24-2015 12:33 PM
Need (comfortable) headrest - 2011 RAM 1500 daleoregon 2011 Dodge Ram Forum 15 12-26-2012 07:33 AM
2011 Laramie 1500 Towing gkorzen Towing 5 06-23-2011 03:12 PM
2011 Ram 1500 rear-end 3:55 or 3:92 Weavs Ram Newbie Checkin! 12 06-22-2011 05:31 PM
Front receiver that would accept a winch - 2011 RAM 1500 daleoregon 2011 Dodge Ram Forum 3 05-23-2011 06:33 PM
