Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 08-19-2011, 12:18 PM
moparguy26 moparguy26 is offline
Vehicle: 1985 Dodge Ram
Trim Level: D-150
Color: purple/black
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:13
moparguy26 is on a distinguished road
Default lower it.
so i want to lower my 85 D150. I found out it has a air bag and a air shock system on it. so im prolly gonna have to take that out. but what is the best way to lower the truck. I dont want it to low..but i do want to lower it some. Also how hard is it to swap the old drum's to disc brakes? Thanks in advance.
Old 08-19-2011, 05:30 PM
Well, one way to lower it is with shorter springs or do a full airbag setup on the truck.
You have drums all the way around? Do you want to do all 4 corners? Then talk to SSBC about your needs. It's as easy as pulling off the old brakes, bolting up a caliper bracket with some dust shields, adding a proportioning valve and putting one of their kits in. In fact, they may have everything you need, including some stainless steel braided brake lines.
Good luck!
Old 08-20-2011, 09:39 PM
TenneSST's Avatar
TenneSST TenneSST is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
Color: Black/Silver stripes
Rep:134
TenneSST will become famous soon enoughTenneSST will become famous soon enough
I lowered my 1980 D150 with van lower control arms (3") and an axle flip (6"). I have the complete write up on another site, but I bet the mods would frown on me linking you to it. If you'd like, I can post it here.
Kevin I.
http://www.ramforumz.com/image.php?type=sigpic&userid=5052&dateline=1301683  967
Old 08-25-2011, 11:35 AM
Trim Level: D-150
Color: purple/black
Rep:13
Well im prolly gonna do away with the air bags i have now, they came with the truck, i tested em and they work but dont think i need them.
Ok that sounds good. Thanks for the help. Ill google them.
Good luck!
If you want to post it or email it to me that would be awesome. Thanks!
Old 08-25-2011, 08:51 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
You might look into swapping rear ends also in order to get rear discs. Might be easier to swap one in from a newer Ram or big body Mopar car.
Old 08-25-2011, 11:14 PM
bagged88's Avatar
bagged88 bagged88 is offline
Vehicle: 1988 dodge ram d100
Trim Level: se
Color: black/silver
bagged88 is on a distinguished road
i did my truck the same way flip kit and what not
Ram Enthusiast
Old 08-26-2011, 02:38 PM
Trim Level: D-150
Color: purple/black
Rep:13
hmm, ill have to see if i can get one.got an idea which rear end will be a good one to get?
Old 08-26-2011, 02:57 PM
Trim Level: D-150
Color: purple/black
Rep:13
Here is a picture of what id like to get to almost. maybe not so low but very close to it as possible.
Old 06-25-2012, 10:46 PM
blackedout12's Avatar
blackedout12 blackedout12 is offline
Vehicle: 2012 Dodge Ram
Rep:19
blackedout12 is on a distinguished road
My first truck was an 87 Dodge Ram 150 Long Bed. I have been looking all over to find one but SWB. I live in SC, and wouldnt mind traveling a little ways to find one. I have a factory set of Dodge 20's to put on, and low a few inches.
Thanks
McG 2/4, Smoked Tails/3rd, Tonneau Pro Tri-Fold, Debadged, Paint Matched Interior, FlowMaster Exhaust, LED Brake Light Bar, K/N Drop-In
Mods from Bully Performance:
AirLift 1000's, Jet T-Stat 180*, Vararram-T1000-Future Mods--Ordered
Old 08-24-2012, 10:00 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
There is other ways to a short whl bse. A local body shop has been making a good living of turning lng bse into short whl bse truck. and other custom work. I bet there is someone in your area that can do it.
Lower Ball Joint Replacement Help Needed! Ibreak4Change Suspension 13 09-05-2014 12:57 AM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Lower Control Arm Issues!!!!!! abmorrisc12 Suspension 0 03-02-2011 12:03 AM
To lower or not to lower flacrkr1ton Suspension 6 07-04-2010 11:05 AM
