Old 08-19-2011, 01:22 PM
wvmtb's Avatar
wvmtb wvmtb is offline
Vehicle: 2011 Ram 1500
Rep:14
wvmtb is on a distinguished road
Default cat-back or replace muffler
I have a 2011 ram 1500. I like the way it sounds but i would like for it to be a bit louder. Not bust your eardrums or wake the neighbors up at night loud. Just enough to make it sound a little meaner. Performance gain isn't that big of an issue. The cheap way would be to just replace the muffler. What is the benefit of replacing the complete exhaust with a cat-back system? Is it worth the extra money?
I believe cat-backs systems are bolt on. I would assume you can just unbolt the existing exhaust (at the cat) and bolt this in place without having to worry about any leaks via a gasket. Am I correct?
With just replacing the muffler I would guess you have to have the old one cut out and the new one welded in place by a shop. Adding to the cheaper cost of just a muffler.
These might be some stupid questions but I'm at work and can't go craw under the truck to answer the simple questions. And I know next to nothing about exhaust work.
I don't have much to say here so here it goes...... "_________________" enough said!
Old 08-19-2011, 01:36 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
The CatBack will give you the sound level you want,
the question is do your want to spend $450.
Retail price is around $900, Lowest price I've seen posted here is $450: http://discountperformanceexhaust.co...9-p-19977.html
Yes its a bolt-on you can easily DIY within an hour on your driveway. (Its actually only Muffler back)
If you do like I , and several others did and sell your new take-offs for $200, You're only out $250
not much more than muffler/labor for welded in, and keeps the stock crappy little tips
There's a few threads I've posted already with pics and video clips
Here's the most recent one (I think)
http://www.ramforumz.com/showthread.php?t=84922
Old 08-19-2011, 01:39 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
The "cat back" systems for your truck (at least magnaflow's) you have to cut off the existing pipe, then the new system can be clamped on....not real hard if you have a sawzall or similar. There are no "unbolting points" between the cats and muffler, except right at the muffler I believe. For your application I would recommend just swapping the muffler, I think it is clamped in, so you could easily do it yourself. The stock system actually is pretty decent anyway, the only two bad points are the stock y pipe and the stock muffler. If you get the "cat back" system you're essentially just replacing the pipe that's there with the exact same pipe, then adding a good muffler...If you want good sound and not too loud get a longer muffler (18" or 22"). There is a 22" magnaflow and y pipe for sale on this forum right now for like $120 I think, you could either resell the Y pipe or have a shop put it in for you (won't help sound much, but will give a slight performance boost). I bet the muffler cost more than $120. It all looked new just not installed.
Sean
Old 08-19-2011, 01:40 PM
snrusnak's Avatar
Rep:1388
I thought you had to cut the pipe shorter between the muffler and y pipe black ram hemi...^
Sean
Old 08-19-2011, 01:47 PM
Rep:561
No cutting for the CatBack (Part#16869)
only Cutting would be if you want to swap out the Y pipe
You are also incorrect about the "exact same pipe after the muffler" Stock pipe after muffler is only 2.25"
The Cat Back has 2.5" Mandrel Bent Stainless Steel, and the Stock Resonators are deleted (about 15 - 20 pounds each)
and the Entire system also has a LifeTime Warranty
Do I even have to Mention the Tips that Are Worth $100 each on their own?
with just a muffler swap for $200+ you'd still be stuck with factory reso's and little single walled bean tin tips...
really Dodge?....REALLY?
if you're going to pull your tips out of the Caliber parts bin,
at least make the bumper cut-outs 4" instead of almost 7" LOL!
Old 08-19-2011, 01:55 PM
snrusnak's Avatar
Rep:1388
I stand corrected
I understand this, but he said he wasn't all that concerned with performance, so for all intensive purposes I think the muffler swap would be in his best interest (as far as $ for the buck). The stock system with a high flowing muffler would perform well, especially on an otherwise stock engine...
Sean
Old 08-19-2011, 01:59 PM
Rep:561
Most shops around here want $200-$250 to weld in a Magnaflow
Just saying it's not always cheaper
Mufflex makes a bolt in kit, but even that's $250 after shipping LOL
So there's stock w/muffler swap welded $250
Stock with bolt on mufflex muffler system $250
or Full CatBack, AWESOME 5" Twin Cannon Polished Stainless Steel Double Walled Tips, Full Warranteed for LIFE! for net $250
You pick
Old 08-19-2011, 02:05 PM
snrusnak's Avatar
Rep:1388
^true, but I know around me it wouldn't cost half that much to just have a muffler welded in. Some things are up to opinion too, like I personally don't normally care for exhaust tips, and think the stock ones basically look the same as the aftermarkets....but that's all opinion. I like exhaust to be heard, not seen...All depends what he wants and wants to spend....you laid out the main options for him
Sean
snrusnak's Avatar
Rep:1388
oh and I always seen to have a tough time selling stock parts...
Sean
Old 08-19-2011, 02:11 PM
Rep:561
Whatever Dude,
You dont even have a Sport with duals or a Hemi,
...no body wants your 4.7L SLT takes offs LOL!
DynoMax VT Muffler Clifton Exhaust 15 10-31-2012 09:38 PM
Muffler set up that will not lose low end power? Litzner8 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 08-17-2011 03:02 PM
Cat Back and CAI tomorrow - question for cat back owners mtnbkr123 2011 Dodge Ram Forum 11 08-10-2011 11:48 AM
Magnaflow and Borla Muffler Fury 2010 Dodge Ram Forum 6 03-24-2010 08:27 PM
Muffler update... GregInAtl Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 3 12-26-2009 12:23 PM
