Old 08-19-2011, 08:09 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Default Component question..
So I found out at work today I can get a HEFTY discount on all kicker products, which has rapidly changed my direction on the stereo idea.
Im now leaning toward this as a setup
Kickers in all doors/dash if they work nicely amplified
a Kicker 12L7 in an 18x18x18 (~2 3/4cft) with a slot port on the floor in the backseat between the center console and the middle of the rear bench
1000RMS @ 2Ohm for the sub (ZX1000.1)
Whatever amp the components need
Pioneer AppRadio headunit as soon as it is available.
Truck will have a Optima RedTop (from my Camaro, that car is going batteryless)
I know this is a very vague type of post, but what is everyones opinion on this. Ive heard mixed things about people opinions on Kickers components and I need something that will keep up with that L7, its going to hit freaking hard
2011 Big Horn 4x4 -SnowWhite-
Old 08-19-2011, 08:16 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
The only real problem I have with Kicker is that there are others out there with better sound quality, however since you seem to get a rather large discount you should be able to get more for the same amount of money you were originally planning on spending.
Old 08-19-2011, 08:28 PM
SS4Luck's Avatar
Rep:310
I have the same problem. I was originally going to try alpine/infinity/jlaudio route, but the cost of my system has been cut almost in 1/2 if not more, so its too good a deal to not run kicker stuff. Plus I LOVE the way L7s hit, even it the SQL is crap
Old 08-19-2011, 08:31 PM
CJ.2007Ram's Avatar
Rep:28
Yes the L7s are beasts. My buddy has one of the little 8 inchers in a Jeep Wrangler with a couple hundred watts RMS and even it is stupid loud in an open environment.
2009 TSBs BlueJet 2009 Dodge Ram Forum 38 10-28-2014 06:03 PM
Oil question and question on finding post EWC88 Oil Change 8 07-01-2011 09:11 AM
component speaker question deathdealer21 Custom Dodge Ram Interior Modifications - Custom Audio / Video 7 05-02-2011 06:47 PM
Question Regarding Replacement LED Bulbs marko7717 Custom Dodge Ram Interior and Exterior Lighting 5 03-22-2010 10:43 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
