Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-22-2011, 07:42 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
You get a few trans options with the flashpaq purchase, but to get full control and all the options yes you have to buy the "advanced trans upgrade" or whatever it is called....yes it is somewhere around $40.00.
Sean
Old 08-30-2011, 11:23 PM
azzo540 azzo540 is offline
Vehicle: 07 Hemi Ram QCSB 4x4
Trim Level: laramie
Rep:21
azzo540 is on a distinguished road
Send a message via Yahoo to azzo540
i have to the dsp for my supercharger but if i could i would go back to my superchip 3865 for tranny tune cause that would help save my tranny from my s/cr.
i miss my tranny tuning
07 1500 QCSB Laramie "Black Betty" Magnuson supercharged, "ATS Diesel" Tranny w/ TCI breakaway TC, Dynatech Super Maxx LT headers, FM Cat-back, K&N
custom doors courtesy of "Axle Break Hill"
Old 08-31-2011, 01:28 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Originally Posted by Crash View Post
If I did my reading right, the trans tuning you pay extra for, no?
No you do not have to pay for the trans tune. Chrysler controls 75% of your torque management by de throttling rpms at shift points and softening the shift pressure at high rpms. SC quick tunes from 87 to 93 and tow comes with a preset trans tune at around 8% TM and a first to second shift point at 6200 rpms with more responsive downshifting. You can adjust the rev limiter (6400 sweet spot), speed limiter to 140 and adjust your preset shift points while keeping the SC tune of your choice. You can also disable the awful MDS. The real beauty of the advanced tune is for lowering TM even further to say like 6% and learning the parameters to have full control over downshifting to your rpm specifications at will.
Old 08-31-2011, 11:18 AM
snrusnak's Avatar
Rep:1388
I don't believe that's correct, I think they have changed the way it works...on mine(bought this year) the only trans tuning options I have are shift points, and torque management setttings of stock or superchips.....you have to buy the advanced trans upgrade for like $40 or so to get full control.
Sean
Old 09-06-2011, 01:10 AM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
can the SC disable MDS? Im torn between the 2. I had a predator lined up but that fell through. Maybe Ill go with the SC, seems how I probably wont buy a cam ever.
How is the MPG gain between the 2?
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-06-2011, 05:11 AM
Trim Level: laramie
Rep:21
Yes sc can disable mds system and I got better fuel economy but it is a hilly area here
Old 09-06-2011, 06:45 AM
RadioFlyer's Avatar
Rep:146
azzo540 is correct, you can disable MDS. I have mine disabled but I can't tell any difference in fuel mileage being my truck is an ST. I can tell you one thing though, I'll never enable it ever again. Unlike before, the performance and sound is much smoother and consistent. And btw, if you get the 3865 it does come with preset SC trans/tunes (quick tunes) so you do not have to buy the advanced transmission tune. You can also adjust the shift points, rev limiter, speed limiter, and tire size without altering any other part of the SC tunes. Just to be clear, the advanced tune is specifically for controlling downshifts to your specified parameters at will and changing the torque management from SC tune to 6% (max recomended) if you are not satisfied with SC preset trans tunes. You can go to a more aggressive trans tune or tone the SC trans tune down. I like the SC trans tune, the difference is night and day. Keep in mind that if you purchase the advanced trans tune it will take some time to get use to as it is complicated for most who try. Just make sure when you buy the SC programmer that you download the latest software. You will first have to register your tuner, name and vin# of your truck on the SC site to update the tuner.
Old 09-06-2011, 06:34 PM
Trim Level: laramie
Rep:21
i miss the advance tuning opt.
Old 09-09-2011, 12:23 PM
RadioFlyer's Avatar
Rep:146
Two things, I found out that the SC TM settings are around 12% and not the 8% like I stated. Second, there is a new software update 3.20.11 that recently came out. I updated mine and was having problems trying to get it to install. After several attempts, the old software was still in properties. I had to set it back to the stock tune and erase the Easy Update program and files (in programs) completely for it to work. I'm telling you this in case you haven't done this update and decide to do it. I set my first to second shifts at 6100 rpms and second to third at 6000rpms. I set the rev limiter at 6400 rpms and the speedo to 140 mps all on a SC 93 tune (no advanced trans tune). I noticed a big difference between the 91 and 93 tune. I could sometimes brake the tires loose from a 15 mph roll even when it was stock but more easily with the 91 tune. But with the 93 tune, this thing breaks the tires loose from a 30 mph roll (on and off) all the way to second and some in second. I haven't and won't try it from a dig because of my new tires, I want them to last. Keep in mind that my truck is an RCSB 4X2 with 3.92 gears with 31" tires on 17's. It's 3 to 400 lbs lighter than a 4X4 RCSB and much lighter than the QC and CC. That's one of the reasons why I chose the RCSB 4X2 with 3.92 gears. That being said, I don't know what it will do for other size trucks but SC TM is a huge benifit over DS for stock (only) trucks. Good luck with your tune if you haven't done it yet and plan to.
Old 09-09-2011, 12:58 PM
Trim Level: laramie
Rep:21
they released a 93 tune finally
damb it
Super Chip Vs Gear Ratio Uncle Nick Newbie Checkin! 12 08-30-2011 01:07 PM
Anyone of Carr Super Hoop Steps on their 2nd Gen with photos jjklongisland Body & Interior 5 02-03-2011 02:25 PM
Flowmaster Super 40 or Super 44 for my true dual 01 Ram? beau21 Exhaust 10 02-03-2011 01:45 PM
CAM or CHIP? bigtallcampbell Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 07-05-2010 08:57 PM
Which brand super chip cpabrams3 Newbie Checkin! 6 08-27-2009 11:22 PM
