Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
View Poll Results: Which one is recomended.
Stainless Steel 8 100.00%
Aluminized Steel 0 0%
Voters: 8. You may not vote on this poll
Old 08-20-2011, 01:10 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
Default Exhaust Stainless vs Aluminized Steel
Which one is recommended?
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 08-20-2011, 02:57 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Stainless steel generally last longer especially here with the amount of salt they use on the roads in winter, aluminized is cheaper and usually lasts 2-3 years.
Old 08-20-2011, 09:25 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Had a few different aluminized mufflers and they all rusted to some extent. My current muffler is stainless and still looks brand new after almost two years
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 08-20-2011, 11:37 PM
Stainless will last longer but if you aren't close to the Gulf Coast or in an area where they deice the roads using corrosive materials, aluminized works just fine.
Old 08-21-2011, 10:30 AM
Drake371's Avatar
Rep:83
looks like i'll spend the extra bucks and get the stainless system.
Old 08-21-2011, 11:24 AM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2006 Ram 2500 Quad cab 4x4
Color: Atlantic Blue
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER Send a message via Skype™ to DOZER
I'm going that way too. For the money it's worth probably never having to replace it.
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 05-15-2013, 02:04 PM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
I'm in the desert of central CA and its actually proving difficult to find a muffler shop which carries 309 stainless... I move all over the country so I need the protection... Probably going to have to drive quite a ways to find the right shop.
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 01-19-2014, 08:09 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Definitely stainless steel, but not all stainless steel is created equal:
300 Series—austenitic chromium-nickel alloys
Type 301—highly ductile, for formed products. Also hardens rapidly during mechanical working. Good weldability. Better wear resistance and fatigue strength than 304.
Type 302—same corrosion resistance as 304, with slightly higher strength due to additional carbon.
Type 303—easier machining version of 304 via addition of sulfur and phosphorus. Also referred to as "A1" in accordance with International Organization for Standardization ISO 3506[6].
Type 304—the most common grade; the classic 18/8 stainless steel. Also referred to as "A2" in accordance with International Organization for Standardization ISO 3506[7].
Type 309— better temperature resistance than 304
Type 316—the second most common grade (after 304); for food and surgical stainless steel uses; Alloy addition of molybdenum prevents specific forms of corrosion. Also known as "marine grade" stainless steel due to its increased resistance to chloride corrosion compared to type 304. SS316 is often used for building nuclear reprocessing plants. Most watches that are made of stainless steel are made of this grade. Rolex is an exception in that they use Type 904L. 18/10 stainless often corresponds to this grade.[1] Also referred to as "A4" in accordance with International Organization for Standardization ISO 3506[8].
Type 321— similar to 304 but lower risk of weld decay due to addition of titanium
400 Series—ferritic and martensitic chromium alloys
Type 408—heat-resistant; poor corrosion resistance; 11% chromium, 8% nickel.
Type 409—cheapest type; used for automobile exhausts; ferritic (iron/chromium only).
Type 410—martensitic (high-strength iron/chromium). Wear resistant, but less corrosion resistant.
Type 416— easy to machine due to additional sulfur
Type 420—"Cutlery Grade" martensitic; similar to the Brearley's original "rustless steel". Also known as "surgical steel". Excellent polishability.
Type 430—decorative, e.g., for automotive trim; ferritic. Good formability, but with reduced temperature and corrosion resistance.
Type 440—a higher grade of cutlery steel, with more carbon in it, which allows for much better edge retention when the steel is heat treated properly. It can be hardened to Rockwell 58 hardness, making it one of the hardest stainless steels. Also known as "razor blade steel". Available in three grades 440A, 440B, 440C (more common) and 440F (free machineable).
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 01-20-2014, 10:43 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
409 SS is great for the price as long as you don't care it looking "burnt" and having mild surface rust.
Aluminized steel can hold up ok but depends on the environment it's used in and remember the welds will need protected as well.
Sean
Exhaust FAQ snrusnak Dodge Ram Knowledge Base 18 05-02-2013 12:28 PM
Nerf bars/tube steps jaxn Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 14 08-18-2011 12:34 AM
Braided Stainless Steel Brake Lines Question WesGPS Brakes 11 12-26-2010 11:37 PM
Exhaust question regaurding aluminized steel 2SSick Exhaust 7 08-26-2010 09:03 PM
Stainless Steel Oval Nerf Bars? Tommyguns Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 5 05-31-2010 10:31 PM
