Old 08-21-2011, 03:42 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default 85mm vs 90mm Throttle Body Upgrade
I wanted to upgrade my throttle body, but I see on Moes website it says that tuning may be required... I think at some point I remember seeing that a 90 wouldnt have really an advantage unless you change your intake manifold, but if thats the case why does the 85mm say you can just use it and the 90 say tuning required? Which would yall recommend? Also, anyone get the 85mm that moes makes themselves? Thanks!!
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 08-21-2011, 04:25 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
the 90mm is overkill unless you have plans for forced induction.
Old 08-21-2011, 05:16 PM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Got this puppy of Dans Fastman Website
HEMI TB SIZING RECOMMENDS:
My Standard Modified Hemi TB is an impressive improvement over the factory Hemi TB. It is absolutley perfect for most applications. This TB covers everything from bone stock through the typical bolton additions like aftermarket Air Intakes, Exhausts, and Programmers. My Standard Modded Hemi TB is an excellent value and will improve your performance nicely.
I do offer the bigger 84mm Hemi TB. It is meant for built motors of the next level which require more cfm than my Standard Modded Hemi TB can deliver. This means Ported Heads, Cams, Stroker Motors, and Boosted Applications.
While the "Bigger is Better Theory" is always an evil temptation proper TB sizing does not work this way. All you need to do is match your motors air requirements. Going bigger than necessary is not going to give you anything extra. Follow my recommends and get a good result.
Old 08-21-2011, 08:02 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Exactly like ^^
If you put too big of a throttle body on it can reduce intake speed and hurt your performance. When you dont have a need for all the air it slows up in the intake manifold and isnt pulled in as well as it could be.
If you arent heavy into the mods, you dont need a giant TB
2011 Big Horn 4x4 -SnowWhite-
Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 49 02-05-2014 04:02 PM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 06:53 PM
Throttle Body Upgrade Red05Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 05-31-2011 10:34 AM
Trasmission Help!!! bigjeff64 5.9L V8 Specific Topics 12 02-28-2010 10:58 PM
