I just installed the Tailgate Easy Lift but am not happy - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-21-2011, 03:35 PM
mytruck mytruck is offline
Vehicle: 2011 1500 Longhorn 4x4
Trim Level: Longhorn
mytruck is on a distinguished road
Default I just installed the Tailgate Easy Lift but am not happy
I just installed the Tailgate Easy Lift.
I am not happy because when the tailgate is down, it is at a 70 degree angle and not the 90 degrees that it should be. The spring is holding it up nearly 20 degrees unless I put some weight on it.
Anyone know how to correct this?
MODS: Truck Covers USA American Roll Cover, BedRug, DeboStep, Tailgate Easy Lift.
Old 08-21-2011, 03:57 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
I had the same thing happen with mine. Ended up taking it off bc I wasn't happy with the tailgate only going down part way.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 08-21-2011, 04:16 PM
Rep:2929
Hoppy EZ LIFT new GEN 4 Dodge video
http://www.etrailer.com/tv-demo-hopp...ist-74211.aspx
Old 08-21-2011, 04:34 PM
Longhorn2011 Longhorn2011 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Laramie Longhorn
Color: White/White Gold
Longhorn2011 is on a distinguished road
Take it off. The 4 Gen Ram has something similar already built into the tail gate. That video is not of a 4 Gen, look at the tail gate and the tail lights.
Old 08-21-2011, 05:48 PM
Rep:2929
I think that i like the DEE ZEE assist better anyway
Old 08-21-2011, 07:47 PM
I just went to the grocery store. When I got back I placed two 3 lb bags of onions on the tailgate and this weight of 6 lbs was enough to push the tailgate flat.
I will try it as is for a while and see if it will flatten out.
Old 08-21-2011, 07:51 PM
turk1270 turk1270 is offline
Vehicle: 2009 dodge ram
turk1270 is on a distinguished road
i have the factory one and my tailgate is flat
Old 08-21-2011, 09:00 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
whats the part number on yours sir?
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 08-21-2011, 09:18 PM
xsivone xsivone is offline
xsivone is on a distinguished road
I picked up the one from OReillys and it wasnt flat until after a few uses
maybe just give it some time?
Old 09-05-2011, 10:54 PM
WSpeedRacerZ28's Avatar
WSpeedRacerZ28 WSpeedRacerZ28 is offline
Vehicle: 2015 Dodge Ram 1500
WSpeedRacerZ28 is on a distinguished road
I installed the Stabilus EzDown on my truck today. (Sachs EZDown - Lift Support, Part # SG314900EZ) from Oreilly Auto Parts ($29.99 + tax). Installation with instructions was easy and quick. Removing the cable travel limit washer was a little tricky - just got to grip it with pliers and use the provided torx wrench to unscrew it from the bolt. The heat shrink split in two but I think this was because of my high heat torch I was using. I taped it nice and neat with electrical tape until I get another piece of heat shrink and find my heat gun.
Overall this took maybe 5-10 minutes tops and it works great. My tail gate goes down to the same level as it did before I installed the EZDown.
If you are looking for this type of product I highly recommend the one I installed - cheap, easy, and it works!
How-To: Installing Power Tailgate Lock iRockCrawler Dodge Ram Knowledge Base 68 09-24-2016 11:54 AM
DYI OEM rear view camera tailgate connector vyruz Electrical 5 12-25-2013 03:21 PM
Ram Eyes installed! Excoastie Custom Dodge Ram Interior and Exterior Lighting 43 08-01-2013 09:22 PM
Body Lift installed... *pics* Pud1309 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 29 08-11-2012 08:28 PM
Installed Pop n' Lock Power Tailgate Lock Danstona Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 5 08-10-2009 09:09 PM
