Old 08-21-2011, 04:26 PM
spike083189 spike083189 is offline
spike083189 is on a distinguished road
Default Truck pops out of gear
I have a 1994 Ram 1500 with almost 230,000 miles on it. When i am on a smooth road it shifts fine but whenever i go over a bump or something in the road it will shift into neutral. I have no clue why it does this. Anyone got any ideas on why it does this or how to fix it?
Old 08-22-2011, 10:37 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
*rolls eyes* Common issue, remove the transmission oil pan, then remove the shift linkage then remove the valve body. Their is a metal gear with notches well their is a spring loaded ball sometimes the metal gear gets loose on the shift shaft and then the balls pops out and well the transmission can shift out of gear. The only reason it jumps gears when the engine is on is because the transmission can't be shifted unless their is hydraulic pressure to shift. Anyways you just need to remove the valve body and either replace this small gear or sometimes you can hammer the tangs that hold it to the shaft. Very small part I forgot the name of the part with the some odd hundred parts in a transmission lol I think it's something like crows gear something like that. But this is typically what causes the transmission to jump out of gear also have a loose shifter. If you check all this and everything seems fine then report back to me and then we can talk about more severe problems.
Old 08-22-2011, 10:42 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. I'm not the first and won't be the last to ask ~ How about posting a few photos of your truck? I'm here to help you navigate the site so don't forget to Checkin at the Newbie Checkin and post some photos!
Our young mechanic above is pointing you where I would.
My truck shakes like an alcoholic captainmorgan Suspension 2 04-26-2012 09:38 PM
disappointed with my 2011 ram truck tomhrrs69 2011 Dodge Ram Forum 19 02-24-2011 09:38 AM
First time truck owner Kleeeen Newbie Checkin! 15 09-10-2010 10:47 PM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 12:02 PM
Truck Bed Crooked?? Kdrake 2009 Dodge Ram Forum 9 03-02-2010 12:25 PM
