Old 08-21-2011, 04:48 PM
sherker55 sherker55 is offline
Vehicle: 1996 1500 2wd
sherker55 is on a distinguished road
Default 2wd to 4wd conversion/lift questions
I posted something similar a few months back but haven't done anything yet. Truck is a 1996 1500 2wd w/5.9 It basically looks like a low rider compared to the 4wd version. That is the look we are going for. So the question is then, can we just get 1500 4wd coils/springs and shocks to swap out with the old ones? not looking to "lift" it any higher than how the 4x4 stands. Let me know what we need to do, thanks
Old 08-23-2011, 11:12 AM
RAM3QRTTON4X4's Avatar
RAM3QRTTON4X4 RAM3QRTTON4X4 is offline
Vehicle: 1999 Dodge Ram 2500
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
RAM3QRTTON4X4 is on a distinguished road
you can try just a body lift, or a 2-3 leveling kit/suspension kit would do the trick.
1999 Dodge Ram 2500 Laramie SLT LD, 5.9L 4x4, ext cab, long bed. still ticking on 140k miles.
Old 08-23-2011, 12:18 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Check out fat bobs garage website, they have a bunch of different options for 2wd leveling kits.
Measure from center of your axle on the back wheel and the front and the difference will tell you how high you need to go.
I would think a leveling kit would be alot easier
Old 09-01-2011, 10:56 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
lmc truck sells a 2" kit for the 2 wheel drive for around 100.00$ coil and shocks inc. i thought about it for mine.
Old 10-27-2011, 10:55 AM
jaidenwarren's Avatar
jaidenwarren jaidenwarren is offline
Vehicle: 1996 dodge ram 2wd ext cab
Color: black and white
jaidenwarren is on a distinguished road
do a google search on changing the 1500 suspension to 2500 suspension. I found that you can take 2wd 2500 diesel coils and bolt them right up to the front and i'm just gonna put an add a leaf in the rear. But you could put 2500 ram van leaf springs as they are 2.5 inches wide and they will bolt right up.
DubDin Navi/Custom sub centerseat/10k hid kit/3500rear wheel cylinders/2500calipers/14x3 cai
Some reg manti. questions GYac 5.7L V8 Specific Topics 12 04-22-2011 01:40 PM
Lowering questions HEMIBLUDA Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 06-20-2010 06:28 PM
1997 1500 transmission questions ajay080672 5.2L V8 Specific Topics 3 10-15-2009 09:26 PM
Couple questions Quiet Lunatic Electrical 4 09-11-2008 07:45 AM
