Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 08-22-2011, 12:22 AM
duncanmb duncanmb is offline
Vehicle: 2009 ram
Color: red
duncanmb is on a distinguished road
Default Struts leaking on 09 already.
Been seeing some leaking shocks/struts problems on 05-08 rams. My driverside front shocks is leaking on my 2009 ram 1500 4x4. I've been told by a dealer that the 4x4's don't have struts, since the struts actually rotate with the steering. I say this because most of the leaking problems I have been hearing about have been called struts. Can anyone shed some light on the potential problem with the shocks/struts, or is this just a 2 wheel drive issue. BTW I have 18,000 miles on my truck.
Old 08-23-2011, 10:48 AM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
Dealer is replacing both of mine on my 2010 (front)
Old 08-23-2011, 02:52 PM
I'd just tell the dealer to inspect the front end and replace whatever is leaking under warranty. That will avoid the confusion over terms.
I haven't seen a TSB out on this but if the shock has given up, that's pretty obvious to diagnose.
Old 08-23-2011, 06:32 PM
Vehicle: 2009 ram
Color: red
On struts common wisdom is to replace both, but the S.M. told me they're not struts, just spring over shocks on 4x4 front-end suspension. Therefore only replacing the leaking one. Is yours a 4x4 and are both of yours leaking Ramathorne ? I'm wondering if this is a snow job or if he's being straight up with me. BTW he also said my first mistake was to use the internet for info.
Old 08-23-2011, 08:26 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: Waiting on"15 RAM Quad Sport
rick980 is on a distinguished road
First mistake is use the Dealer for info.
Old 08-23-2011, 09:35 PM
JasonK94Z JasonK94Z is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Quad Cab Outdoorsman
Rep:30
JasonK94Z is on a distinguished road
My truck is a 4x4, and they are shocks, not struts. There is an upper and lower control arm, and a rack which located the knuckle. On a strut, the knuckle rotates using the top of the strut as the axis instead of an upper ball joint.
Never looked at the 2wd Ram so I have no idea whats there.
2011 Dodge Ram Quad Cab Outdoorsman
Old 08-24-2011, 09:34 AM
Vehicle: 2009 ram
Color: red
Thanks for the info guys. I feel a little better about what's going on now.
Old 08-24-2011, 05:22 PM
mike49 mike49 is offline
Vehicle: 2009 Dodge Ram 1500
Color: tan
mike49 is on a distinguished road
Wink
Just take anything a dealer says with a (large) grain of salt
Old 08-25-2011, 05:16 PM
09flexquad 09flexquad is offline
09flexquad is on a distinguished road
Yep! Mine was leaking as well. leaking at 39k I was told that the shocks were struts, only to find that they were infact shocks, they are just mounted sort-of like a strut, hence the confusion. I replaced mine myself, the dealer told me right after my warranty on the stockers ran out, and they wanted 100 bucks a pop. Went with Monroe Reflex, and a huge difference in front end handling, and only took an hour. BTW I own a 2wd, pretty much the same setup as a
4x4.
Old 08-29-2011, 10:21 PM
Rep:48
IDK....Dealer said they were both gone, and are replacing them.....
leaking power steering fluid caseyfolkman 5.9L V8 Specific Topics 11 02-02-2011 06:14 PM
Water leaking in back seat DodgeRR Body & Interior 9 01-26-2011 05:30 PM
Lifting via spacers vs via new struts Tommy Behind The Deuce Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 11-14-2010 11:14 PM
Help leaking sunroof Wheelcrazy Newbie Checkin! 12 11-12-2010 02:55 PM
Coolant leaking from AC Compressor...WTF? 96Ram1500 Heating & Cooling 8 09-26-2010 11:08 PM
