Dodge Ram Decals
Old 08-22-2011, 05:32 PM
Kpass3490 Kpass3490 is offline
Vehicle: 1998
Trim Level: Laramie SLT
Color: Green
Kpass3490 is on a distinguished road
Default Lifter tapping?
I have a tapping in my engine and think it's a lifter. Does anybody know if there is any fix for this hand how much it would cost?
Old 08-22-2011, 07:12 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Seafoam or Marvel Mystery Oil added to the crankcase will often unclog a sticky lifter. Also consider an exhaust leak. They can sound just like a tapping lifter.
Old 08-23-2011, 01:49 PM
jssmith76's Avatar
jssmith76 jssmith76 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Sunburst Orange
Rep:26
jssmith76 is on a distinguished road
Send a message via MSN to jssmith76 Send a message via Yahoo to jssmith76
Ok, really stupid question here... Adding oil to the crankcase, is that the same as just taking the cap off and adding oil normally?
Thanks,
Josh
Thanks,
Josh
2009 Ram 1500 Sport 4x2 Quad Cab, Sunburst Orange - Bone Stock
Old 08-23-2011, 03:16 PM
Rep:99
Yeah, same place you put engine oil. You should notice a change in a short time, just a few miles should reveal something. If the noise doesn't change after a hundred miles or so you either have a whacked lifter (not so likely, but possible) or an exhaust leak.
Old 08-23-2011, 03:33 PM
jssmith76's Avatar
Rep:26
Thanks Gen1dak,
I know I definitely got an exhaust leak. but, I was thinking of tossing this stuff in just for the heck of it. If not, just to know that the innards are getting clean, and my baby is gonna run better.
Thanks,
Josh
Old 08-26-2011, 09:47 AM
Vehicle: 1998
Color: Green
I have added Seafoam into the oil and drove it around for awhile and then changed the oil and changed over to fully synthetic (expensive lol). This time I replaced a quart of oil with a quart of synthetic Lucas Oil Stabilizer. I've been driving it like this for awhile now and have to add oil every once in awhile but don't see a leak. I don't think it's an exhaust leak but u can check, what's the best way to tell the difference? And if it does end up still being the lifter and I've done everything I've been told does anybody know how to fix it or how much it would cost? I don't know how to do much work besides simple changes of regular things. Thanks
Old 08-26-2011, 12:35 PM
Rep:99
Did the character of the noise change at all? If it were just a sticky one it would've sounded different. If you actually have a damaged lifter, the only way to fix is to replace it. To home in on it, I'd get under the hood with an automotive stethescope. You may find that the noise comes from somewhere that implicates another engine part. You could have a busted timing chain tensioner. Anything is possible, but lifter design, by nature, is stout and you usually don't see them break unless they've been abused. This is much less possible in computer-controlled engines.anyway, get the scope and probe around, isolate the noise. Does the engine run smoothly? If not it could be a type of knock from a dead cylinder. Getting fire to all cylinders? Could just be a bad plug wire. Anyway, listen to the engine, it's amazing the sounds you can pick up with a cheap auto-scope.
Old 08-26-2011, 05:36 PM
Vehicle: 1998
Color: Green
That sounds good but I wouldn't know what I was hearing in different spots lol. I guess I need to get somebody that knows a little more to do it.
Old 08-28-2011, 01:33 AM
Rep:99
Well you could determine if that tap, tap, tap was coming from the lifter valley or somewhere else.
Old 08-30-2011, 04:27 PM
Vehicle: 1998
Color: Green
I wouldn't really even know exactly where that is lol. So all I would really know is yupp it's tapping somewhere in the engine lol.
valve tapping cathysams 5.7L V8 Specific Topics 12 05-22-2016 06:41 AM
Lifter problem Kpass3490 LD RAM - General Discussion 8 03-27-2011 12:13 PM
Need help... Tapping after oil and plug change NIGHTRUNNER2006 5.7L V8 Specific Topics 22 06-29-2010 01:53 PM
noisy lifter or ? on cold starts rstp 2009 Dodge Ram Forum 21 05-30-2010 01:51 PM
Lifter noise tonyj 4.7L PowerTech V8 Specific Topics 1 09-14-2009 06:35 PM
