LT tire pressure? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-22-2011, 10:40 PM
euromade euromade is offline
Gender: Not Specified
Vehicle: 2011 Quad Cab 4.7
euromade is on a distinguished road
Default LT tire pressure?
Hello,
just put a set of Pirelli Scorpions ATR LT 265/70 17s 121/118s on my 2011 RAM.
So far I like these tires as they are just as quiet as the stock GoodYears I had, while the thread looks more appropriate for some off roading and Michigan winters.
I did notice the truck is a bit "bouncier" now, so I checked the pressure. 48psi in the front and 44 in the back. I am sure this should be reversed, but would like your input. This tire is E-load rated, and according to this site it can hold up to 80 psi!
I do not need this much pressure, however I am looking for some guidance on the LT tire in general, compared to the P rated tires as far as the recommended pressure goes.
Also, I found in some posts as to how low psi on LT tire is more "damaging" compared to the P rated tire.
Thanks much...
Old 08-22-2011, 10:44 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
What does the tire sidewall recommend?
Old 08-22-2011, 10:47 PM
it says max 80psi! does not show recommended psi anywhere on the tire.....
Old 08-22-2011, 10:58 PM
RedRam10's Avatar
Rep:743
I called a friend with a tire shop and he suggested running at 60-75% max under normal driving situations on the LT tire and using max pressures if your under full load or at max towing weight. That would be 52 to 60 psi.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Incorrect door sticker tire pressure recommendation steve57 2010 Dodge Ram Forum 48 09-29-2010 10:38 PM
TPMS Tire Pressure Monitor Light 2010 351 Stang 2010 Dodge Ram Forum 6 08-28-2010 12:59 PM
Tire pressure monitor 2010Ramowner 2010 Dodge Ram Forum 3 04-30-2010 12:41 PM
