Need to know what LEDs fit your truck? - Page 19 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 03-26-2012, 02:57 PM
InDeepWaterBlue's Avatar
Rep:611
Originally Posted by Choquette View Post
thank you very much!
No problem, we all have/had those questions. Luckily for you we've all been through the trial and error method so you don't have to
Old 03-26-2012, 04:44 PM
Choquette's Avatar
Choquette Choquette is offline
Vehicle: 2009 Dodge Ram 1500 Laramie
Color: Black and Grey
Choquette is on a distinguished road
I have a question, I do not know if I'm in the right section cause its for Leds lights but its leds that I'll put insine my headlights, and fog lights, and ANgel Eyes, I was wondering if I could splice the cable that goes to the cargo light switch and plug my angel eyes and leds to it so that way when I turn on my cargo light on it turns everything ON at the same time!
Old 03-26-2012, 05:47 PM
mikeski's Avatar
mikeski mikeski is offline
Vehicle: 2012 Ram Quad Cab 1500
Color: True Blue Pearl
Rep:25
mikeski is on a distinguished road
Send a message via AIM to mikeski
I am having trouble visualizing what you are trying to do. You want to run your cargo lights when you run your LED's and Angel Eyes? Or do you just want to tap the power that goes to that switch to run all the LED's and Angle Eyes?
me...
Mikeski.....
Morimoto Mini H1 Projector's w/ Digital 55watt 6000k HID's, 35W 10k HID Fog Lights, Blue LED's throughout the interior, Bed and Reverse LED's, Oil Catch Can, 4" vent to stock air box and two beady red eyes. Where will the madness end????
Old 03-26-2012, 06:19 PM
Choquette's Avatar
I want to tap to the power that goes out of the switch so when I turn on my cargo light( The light behind the Cab that is with the 3rd break light) I turn on the others lights too! (Nevermind I read that there is always 12V on and it goes with a resistor to the CPU that detects the drop down courant. ANd btw the Cargo lights dont stay on plus than 20min) So I'll need to put another switch or you got an idea what switch I could use that stays on? If I want to put a relay for the led what kind should it be. Im trying to find an alternative to use a switch that Is already existant! I could use one of my Map light to use like a switch for my led and Angel EYes. COuld that work?
Old 03-26-2012, 06:58 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Well we could let them go off and have thousands of questions for you to answer, but that's just not very nice lol So I think helping others like you've helped myself and a few others along is the right approach, next time warn me when you go on vacation so I can charge you for my secretarial skills lol
Lol, secretarial skills. Y'all ate hilarious.
Originally Posted by mikeski View Post
Where ya been vacationing?...
Haha I've been vacationing to my engine shop. We turned the key on the dyno for the engine in my camaro about a week and a half ago and been having tuning issues/problems that would make the most patient person pull their hair out
2011 Big Horn 4x4 -SnowWhite-
Old 03-27-2012, 12:57 PM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:47
Pyroboy5000 is on a distinguished road
you could cut into the park lights. or if you have drl's on your truck you could splice into them. me personally i have a swith in the cab and i have it straight wired to the battery with a 15a fuze. it has been running for at least an hour straight once when driving and the fuze hasnt blown. one really good way you could wire it is to splice into the ignition wire somewhere so that it is on only when the car is running, and you could have a switch on the dash to turn them off if you wanted to.
if it was me, and i wanted them on always, drl or parking light splice. the only reason i straightwired mine, is because i was in a hurry to wire them up and didnt have the time to locate the ignition wire. i kinda want my halos to be independent of the park lights for right now. but if i get the awesome headlights that go with my fog lights, i will wire the halos on the fog lights to the halos on the headlights and hook them into the parking lights.
the parking lights are always on unless you turn all lights off. they come on when the headlights are on. it would probably be best to use the parking lights if these are halos that are in the headlights. that is what ill do eventually when i get halo headlights.
i hope this helps you. good luck.
Confederate Ram TRX
Old 03-27-2012, 01:28 PM
Rep:611
Glad you brought that up Pyro, why don't you want to splice into your side markers or the fog lights?
Old 03-27-2012, 02:32 PM
Choquette's Avatar
What is DRL ? I wanted to use an existing switch so I didnt have to drill a hole and put a switch. So I thought the Cargo light would have been a good idea! I could use a relay with the cargo light switch so when I turn on the cargo light I turn on all the leds and the halos. I switch to do All! But I do not know what kind Of relay I should use!
Old 03-27-2012, 03:15 PM
mikeski's Avatar
Rep:25
This remote would be interesting to wire your accent lights into.
http://www.superbrightleds.com/cgi-b...te_control.htm
Otherwise, just your standard horn relay should do the trick.
Me...
Mikeski.....
Old 03-27-2012, 09:26 PM
Choquette's Avatar
Me...
Thank You I'll look into that! :P
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 12:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
