United Radio
Old 03-28-2012, 09:39 AM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
Originally Posted by Choquette View Post
What is DRL ? I wanted to use an existing switch so I didnt have to drill a hole and put a switch. So I thought the Cargo light would have been a good idea! I could use a relay with the cargo light switch so when I turn on the cargo light I turn on all the leds and the halos. I switch to do All! But I do not know what kind Of relay I should use!
DRL stands for daytime running lights. they are constantly on when your vehicle is on. if i was you, i would wire them into these if your truck has them. if they dont, i would wire them into the parking lights.
I'm back from the dead!
R.I.P Old Blue 2013
Old 03-28-2012, 11:24 PM
yerslo yerslo is offline
yerslo is on a distinguished road
Originally Posted by SS4Luck View Post
Do your cargo lights glow faintly even with your light switch off?
Hey Guys,
I have the same problem with my cargo lights. It seems like they are dimly lit when my headlights are on or have been on and they are very noticeable while driving at night... anyone know why and/or how to fix. i don't really want to get a ticket for this.
thanks
Old 03-29-2012, 08:10 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Check out the LED fix sticky. It's a simple resistor fix
2011 Big Horn 4x4 -SnowWhite-
Old 04-02-2012, 10:20 PM
Trim Level: TRX
Rep:37
i just replaced my interior lights. they are freaking sweet. i cant get a picture right now, but ill try.
i used WLED-xHP10-DAC for the dome light. i was a little worried that it wouldnt work since leds are directional, but i pluged it in and it worked with no alterations.
i used WLED-xHP15-T for the map lights. it was simple. i did have to move one of them in order to get it to light because of the direction, but it was really easy. all in all i think it took about 10-15 minuites.
if anybody has a 1998-2001 ram and they want to get the biggest led replacement that has a different color, i reccomend getting these. they are the absolute biggest that will fit and still be in a different color. the map light replacements are the same size as the actual bulbs, but the dome light replacement is bigger than the actual bulb. the total cost was about $50 and it was totally worth it.
these are so freaking sweet. i can see better than i could with my oem lights. it is bright useable light that is also blue.
...next comes the window controls to blue. i ordered the 5 3mm leds necessary to replace the green leds in the controls. now they just have to get here.
...and so begins the wait.
R.I.P Old Blue 2013
Old 04-04-2012, 10:28 AM
Rise Captain's Avatar
Rise Captain Rise Captain is offline
Vehicle: 2009 Dodge Ram Sport
Rep:31
Rise Captain is on a distinguished road
SS4luckkyy.. quick question.. if I put reverse LEDs in my 09 (so 921 bulb) will they stay lit all the time with a very dim light like my LED 921 in the cargo spot do ?
20% Tints, SS 409 Custom Exhaust, Stubby Antenna, 6K 55w DDM HID's in HI's Lows & Fogs, LED Interior & Exterior Lights, Recon Tails, Red Painted Emblems, Plasti-Dipped Grille, Mopar Racing Stripes, 22" Rockstars - 305/45/22 Nitto 420's, Two 12'' Alpine Type R's Under Rear Seat in a FoxBox
Old 04-04-2012, 11:14 AM
chris0001's Avatar
chris0001 chris0001 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
If you solder a 100 Ohm 1watt resister to one of your LED cargo bulbs they will shut off when not in use, (check out the sticky there is even a pic with the resister soldered on). As for the reverse bulbs, my LEDs are only on when in reverse. Hope this helps you out.
Cheers!
[/SIGPIC]
Old 04-04-2012, 04:53 PM
InDeepWaterBlue's Avatar
Rep:611
Cheers!
Exactly. The 100 Ohm 1 Watt resistor takes care of the "glowing" cargo lamps, but your reverse lights only come on when you put the truck into reverse. I got a handful of warnings over the blue glowing cargo's, pretty sure I would have got a ticket of blue glowing reverse lights
Old 04-04-2012, 05:04 PM
chris0001's Avatar
Color: SILVER
Yup... the police frown on blue plate lights......Got stopped by the OPP and he gave me a warning one morning on the way to work. Atleast he didn't give me a ticket. In Ontario your plate lights can only be WHITE....Shoulda looked into it a bit more.
[/SIGPIC]
Old 04-07-2012, 10:08 PM
mikeski's Avatar
mikeski mikeski is offline
Vehicle: 2012 Ram Quad Cab 1500
Color: True Blue Pearl
Rep:25
mikeski is on a distinguished road
Send a message via AIM to mikeski
Verify that the bulb for reverse goes in from the back. My 2012 has the reverse light coming in from the bottom. So the 921 might be correct but if it does not come from the back you will need a different tupe bulb that will use the reflector.
Me
Mikeski.....
Morimoto Mini H1 Projector's w/ Digital 55watt 6000k HID's, 35W 10k HID Fog Lights, Blue LED's throughout the interior, Bed and Reverse LED's, Oil Catch Can, 4" vent to stock air box and two beady red eyes. Where will the madness end????
Old 04-08-2012, 01:55 AM
SS4Luck's Avatar
Rep:310
I think the testing has show a 194 tower style bulb will work better for the 2012s because it actually shines light into the reflector as well
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
