Old 05-18-2014, 11:54 PM
Chefy's Avatar
Chefy Chefy is offline
Vehicle: 2013 Ram
Color: Grey
Rep:29
Chefy is on a distinguished road
Originally Posted by vyper340 View Post
Anyone know which bulb number is required for under the hood/engine bay?
I am also interested.
Old 05-19-2014, 09:09 PM
Murdered1500 Murdered1500 is offline
Vehicle: 2014 Ram 1500
Murdered1500 is on a distinguished road
I received my 921 LEDs.. and the reverse light is not a 921.. I have the black edition with the upgraded style tail lights and head lights.. I do not think that makes a difference.. can anyone tell me what size the tail lights are and what else share the same part number as the tail lights. thank you
Old 05-31-2014, 03:59 PM
4x4RAM1500's Avatar
4x4RAM1500 4x4RAM1500 is offline
Vehicle: 2014 Ram 1500 Sport
4x4RAM1500 is on a distinguished road
Originally Posted by SShadow1974 View Post
Is there any reason that these should NOT be used for replacement fog lights in my 2014?
http://dx.com/p/pegasus-9006-100w-25...1#.Uvt4ojZdWWY
Did anyone end up trying these?
My build
http://www.ramforumz.com/showthread.php?t=177326
Old 06-06-2014, 10:23 PM
BowhuntnSteve BowhuntnSteve is offline
Vehicle: 2014 Dodge Ram
Trim Level: Sport Crew w/6'4"
Color: Blue Streak Pearl
BowhuntnSteve is on a distinguished road
If you changed the 3rd brake light and it's not a canbus bulb or has a resistor on it, you will get the passenger tail light out message.
I haven't played with the license plate lights yet.
From all that I have read, the only ones that you can change without issue are the cargo lights and the foot well lights. The rest are hit and miss on the interior.
Put non-canbus led's in my 3rd brake light, cargo lights, and license plate lights tonight. No codes on my screen at all for any of them and function fine.
Old 06-06-2014, 11:22 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
Interesting. When I swapped out my brake light, I got the passenger rear brake out msg. Put the incandescent back in, and the error went away.
Maybe the Sport is different than the Outdoorsman? Does the sport have LED tails?
S S H A D O W
Old 06-08-2014, 11:25 PM
Yes have the projector headlamps and led tail lights.
Old 06-11-2014, 10:00 PM
pharmboy2010 pharmboy2010 is offline
pharmboy2010 is on a distinguished road
Installed some can bus leds from superbrightleds in the 3rd brake light and cargo a couple weeks ago with no errors. Installed ebay can bus leds in the backup lights tonight and got the error! Would you try some can bus from superbrights or would adding a resistor work better?
Old 06-13-2014, 02:05 AM
MoldyTaco's Avatar
MoldyTaco MoldyTaco is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
Trim Level: SLT Big Horn Edition
Rep:27
MoldyTaco is on a distinguished road
I believe that all years that have a light under the hood use at 561. Try this and see if it looks like yours.
http://www.superbrightleds.com/morei...d-festoon/244/
" There is a reason we are born with brains in our heads, not rocks!"
Old 06-17-2014, 03:47 AM
Jmc2784 Jmc2784 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Jmc2784 is on a distinguished road
Does any body know when replacing stock lights with LEDs witch ones need resistors and what kind. I'm sure the info is here some ware but don't feel like digging thru 40 pages to find it. Any help would be great thanks.
Old 06-19-2014, 08:20 PM
MoldyTaco's Avatar
Rep:27
From what I have read in this thread a my personal experience it is really hit and miss on each truck. However, if the bulb you are replacing blinks then add a resistor. Basically your turn signals will require a resistor. Check out this thread for more info:
http://ramforumz.com/showthread.php?t=106466
If you have more questions just ask. SS4Luck and InDeepWaterBlue are the two members I have followed what they have posted about LEDs and LED problems.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 12:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 12:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
