Old 08-24-2011, 02:44 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Default When did YOU add a bigger alt and/or extra battery(s)?
Im just wondering at what power level, watt wise, you added to yoru charging system for your stereo
2011 Big Horn 4x4 -SnowWhite-
Old 08-24-2011, 02:56 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Hmmm... I would say if you are going over 1000 watts RMS, then it's time to consider an alternator upgrade. A battery upgrade is never a bad idea no matter what power you are pushing.
I am going to try the "big three" upgrade soon since I have a ton of 4ga. wire laying around. Then we'll look at upgrading the battery... and go from there.
Old 08-24-2011, 03:06 AM
SS4Luck's Avatar
Rep:310
I already have a red top in my truck (left over from the racecar when it ran an alternator) and planned on doing the big 3 when I installed my amp. Im going to be running 1500RMS just to the sub and a 1/0G power wire and was going to order some extra and do the big 3 with 1/0G when I did the amp. Im also going to be running an amp for the component so I plan to be up around 2000RMS total system watts
Any idea where to get an upgraded hemi alternator?
Old 08-24-2011, 03:26 AM
chithead's Avatar
Rep:2078
Ouch...
Mechman 270 amp Dodge HEMI Truck alternator - $449.00
Old 08-24-2011, 01:47 PM
SS4Luck's Avatar
Rep:310
greeeeeat just what i need, another high cost litt part lol time to hit egay!
Want bigger wheels, but I need some edumacation! deanthecrabman Dodge Ram Wheels And Tires 4 11-03-2010 02:25 PM
Lift kit & bigger tires elcabron Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-14-2010 10:03 PM
Bigger Oil Filter for the Hemi! 04ram4X4 Oil Change 2 04-25-2010 11:06 PM
Bigger tires on Trx4 bwheeler0018 2009 Dodge Ram Forum 8 02-03-2010 05:21 PM
Bigger tires /gas milage beaglelee Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 11-16-2009 11:58 PM
